Re gearing
sherpaJL
Keystone State
2019 JLUR Mojito! ~ 2022 JLUR Hydro Blue
The front gears are really loud starting around 40mph and stay loud while coasting down. The rear gears are pretty loud starting around 62mph. I'm at 300 miles in the 500 mile break in. I haven't gotten on it. I have the 2.0L JLUR. I do notice that I'm not in 8th gear more regularly while cruising.
they reused your old bearings
sherpaJL
Keystone State
This past summer, climbing the beginning of our CO mountain pass, twice my Jeep overheated and I had to slow to 55 and move to the right lane. Both were loaded up pretty heavy and both were on 100+ degree days. I'm hoping the re-gear resolves that on hot days, fingers crossed
reduce coolant mix, go 20% coolant / 80% water, add in an additive like WaterWetter
I did this on previous rigs that ran hot, I also added a Flex-A-Lite blade.
I currently don't have issues with heat, but when I do, I have a plan.
Jeep Wrangler JL Re gearing {filename}
arnie_mueller
Arnie
Castle Rock, Colorado 80104
I’m not very smart. I couldn’t run that mix in winter, right? Assuming I cannot, is it easy enough on change the coolant twice a year?
sherpaJL
Keystone State
yup, above freezing.
In the fall I would drain a bit and add in coolant to get me back to 50/50 for the winter.
sherpaJL
Keystone State
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
That makes me a little frustrated because I was charged $1200 for parts and I can get gears and the master install kit for $750+$150=$900, $300 price gouged.
I doubt they reused old bearings. While possible, it's very unlikely since the shop needs to guarantee their work. And someone doing something dumb like reusing bearings would result in a very expensive repair on the shop's dime.
Any tech who got caught doing that would probably have to deal with an involuntary career path adjustment.
A shop that directed a tech to do that would go out of business pretty quickly.
More likely is that the tech made a dumb mistake setting up the gears.
Never attribute to malice that which can be explained by incompetence.
rmeJeep
Dallas
2023 JLU Sahara, 2018 JKU Sport S
I put 35s on my 23 Sahara in December. As expected 8th gear is harder to get to, but it drives great. I took it on some trails and rocks and it performed well. Full disclosure, that was my first time offroad. I'm replacing 3.45 with 4.56 tomorrow. I don't "expect" to ever go to 37s.
My first comment when I saw my 2.5" lift and 35s was "those tires look small".
