Rancho Front Diff Glide Plate Question
JRostek
Orlando, FL
2020 JLUR
Thinking of ordering a Rancho front diff glide plate since I’m not ready to change the covers. Reading the forum, I’ve seen the U-bolts can be a pain but reading Rancho’s instructions, they call for threadlocker in the diff bolts when installing.
I figured this would probably be a horrible idea but wanted to check with those who’ve installed this glide plate. Did you loctite the bolts?
thanks!!
TxJeepers
2025 JLUR '41
Why is the installing the way the manufacturer says to bad?
omnitonic
Southwest Virginia
2021 JLU Willys in Sarge Green
truck driver
I installed a Rancho in the rear. The one for the front is similar.
I don't remember much of anything about the install, honestly. It was one of those I have time to knock this out before work deals, and it was totally uneventful. I think that kit came with a little tube of red Loctite. I did not use the red, as I was planning to regear. I did use blue Loctite on the bolts.
I like it, and would buy it again.
JRostek
JRostek
Orlando, FL
2020 JLUR
My concern is the loctite as eventually, I want to re-gear and change the diff cover. Last thing I want to do is potentially break a bolt in the housing. I think loctite as a permanent bond.
I don’t know much about mechanics and figured I’d ask people who know more than I do
JRostek
JRostek
Orlando, FL
2020 JLUR
Cool. Thanks! I’m in the same boat and will use the blue loctite. Thanks!!
shekmark
Manasquan, NJ
Yes
I installed the front. Super easy ( I am a basic driveway mechanic) I used blue Loctite.
JRostek
JRostek
Orlando, FL
2020 JLUR
I’m an aspiring basic driveway mechanic, still trying to learn the more basic stuff and figured I’d check before I did something dumb. Thanks for letting me know about the blue loctite!!
Upsidwn
Mat
NE, Oh
2021 JLUR
If you use red you can just hit it with some heat down the road to remove it easily. Tells you this right on the loctite bottles. Blue is removable with hand tools, red will require some heat first
JRostek
JRostek
Orlando, FL
2020 JLUR
Thanks for the info!!
shekmark
Manasquan, NJ
Yes
I installed the front diff skid from Rancho. Very easy. I used blue Loctite as well.
wibornz
Ted
lansing, Mi.
JL Unlimited Rubicon
I have the Rancho diff slides on the front and back. I use a lock nut on it and skipped the locktite. I have ran the skids for about 52,000 miles and had them off and on several times.
For some reason, I need to repaint them. LOL. They are tough and they have never worked loose.
Mind you the lock nut comes with the kit.
Not really sure how I rub the paint off them...
Jeep Wrangler JL Rancho Front Diff Glide Plate Question 1632317815711
Jeep Wrangler JL Rancho Front Diff Glide Plate Question 1632317846279
Jeep Wrangler JL Rancho Front Diff Glide Plate Question 1632317914874
I just know that they have stood up to the punishment of Rausch Creek, Windrock, Moab Holy Cross, the Rubicon Trail and hundreds of other trails over the last two years.
JRostek
JRostek
Orlando, FL
2020 JLUR
Actually, I saw you post something about theses glide plates in my searching the forums and it was one of the reasons I’m looking into them. I was like holy sht, this guy beat the piss out of them and they are surviving…sounds like this will be more than enough for me
With all those trails, I can’t see why they would need to be repainted lol
thank you for the feedback on them! They will be added to my next purchase
entropy
Foothills of the San Gabriels
OF top 1% content creator
I beat the shit out of mine. Keep painting them with red rustoleum. Doesnt really match lol but whatver.
I did use the red loctite as manufacturer instructed. Blue should work fine.
wibornz
Ted
lansing, Mi.
I paint them with a Farm red. The paint is used on tractor and farm equipment and is pretty tough.
