Quick tazer question about sleep mode
MntGoat
Doug
TN
2022 Rubicon
Machinist
Im going to reinstall mine.
How many doors do I need on to put her to sleep?
Can I get away with just drivers ?
Joe's_Roxy
Arkansas
2018 JL Rubicon, 2009 JK Sport, 2006 LJ Sport
Quality Manager
With your doors off, your jeep should go to ""sleep" the same as it would if you had doors on. just turn it off and leave it alone for a couple of minutes.
If this is not working, try installing just the drivers door and see if that shuts it down completely.
But, if your Jeep isn't shutting down at all with the doors off...then that is a MUCH bigger problem.
yokramer
A Land of Petty Tyrants
Snark Incarnate
with the doors off you probably should walk away with the keys too so that way they dont keep it awake
RP1
Rob
NoVA
2024 JLU Rubicon 392
both of the above are sound advice, IMHO.
Try making a change and see if it sticks to test your procedure.
Or email zautomotive support - they have been pretty helpful to me in the past.
zouch
Berkeley, CA
XJ, JLUWD
i find it very difficult to get the J**p to 'sleep' if it can 'hear' a key.
i've taken to wrapping my key in foil if i'm trying to do a Sleep Cycle.
i even keep the keys in a foil-wrapped bag (homemade Faraday solution) when parked nearby to get it to 'sleep'.
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
They replied very quickly. Turn jeep off, get off seat that does it
We shall see
MntGoat
MntGoat
Doug
TN
2022 Rubicon
Machinist
So, the simple thing above didn't work...I "assume" it was due to the small space in garage. Need to put doors on today so will try the way I've always done it. Report back later
