Yeah, just I think you can balance that mitigation with goals - if your goal is ultimate diff clearance, you can always mitigate with better line selection (or better driving of a sketchy line, driver mod is always the best mod) and/or being extra cognizant of spotting for the rear diff.Agreed. It's just risk mitigation. Dragging slowly is different than smashing into it. For me, something like Metal Cloak's golden diaper was a no brainer and cheap insurance.
Depends on how often you put big rocks under the body of the Jeep with the tires lower. Generally, so long as you put the wheels on the high spots (provided of course it's a realistic line, obviously), your pinion and yoke should be higher and out of danger. Hits to yokes do happen, but IME they're rarer. IMO, just carry tools to unbolt the rear driveshaft if it does happen and work in FWD, a spare bottle of gear oil isn't a horrible idea either.What about pinion and yoke/flange protection?
Two rear diff skids that I have seen offer protection to the pinion and yoke.Depends on how often you put big rocks under the body of the Jeep with the tires lower. Generally, so long as you put the wheels on the high spots (provided of course it's a realistic line, obviously), your pinion and yoke should be higher and out of danger. Hits to yokes do happen, but IME they're rarer. IMO, just carry tools to unbolt the rear driveshaft if it does happen and work in FWD, a spare bottle of gear oil isn't a horrible idea either.
AEV has one as well, a stamped one at that. Between RC and NVM for price (that NVM one is wild, $500+ for a diff skid), but it's AEV so you know it's more expensive than it needs to be.Two rear diff skids that I have seen offer protection to the pinion and yoke.
Next adventure motorsport on the high end. Or you can spend 1/4 of the price on Rough Country.
I have the RC to have a peace in mine. Works great.
I agree on AEV overpriced products. I would stay away from most RC products, but I cant say enough good things about their skid plates. Great cost to performance ratio.AEV has one as well, a stamped one at that. Between RC and NVM for price (that NVM one is wild, $500+ for a diff skid), but it's AEV so you know it's more expensive than it needs to be.
I'm a little more meh on them - buddy of mine runs their front D30 skid since it's the only one still available for D30s that wraps underneath the housing and he had a chunk of weld just come off.I agree on AEV overpriced products. I would stay away from most RC products, but I cant say enough good things about their skid plates. Great cost to performance ratio.
As many mentioned, I run diff skids more for gliding than protecting. The difference between gliding through a rock and getting hung up by the ribs is noticeable.
Just a rookie‘s perspective. The more experience you have, the less damage you will do I suspect. I’m still at the bad line picking, skid scraping, tire gouging stage without a spotter.I'm a little more meh on them - buddy of mine runs their front D30 skid since it's the only one still available for D30s that wraps underneath the housing and he had a chunk of weld just come off.
But honestly, the JK rear 44 has a similar valley and I never had any issues with it getting hung up when it would drag. I do run the Rancho skids because I'm liking keeping the stock diff covers for heat dissipation and really all I notice different is I hit the skid more than I would hit the diff otherwise.
Yes and no. Overconfidence, I suspect, has done in (or caused more damage to) more rigs than has almost anything else, including inexperience, and overconfidence is a trait that runs the gamut from rookie to veteran wheeler. One of the best ways to figure out who's going to do damage to their Jeep - IMO - is to look for the person with the biggest, stickiest tires and the most engineJust a rookie‘s perspective. The more experience you have, the less damage you will do I suspect. I’m still at the bad line picking, skid scraping, tire gouging stage without a spotter.
Rear diff also deals with the consequences of falling off the line when traction goes to hell too, while the front diff usually stays on line through a climb. But, IMO, aiming the rear diff can be done to a greater or lesser extent depending on wheelbase. A lot easier in a 2 door to just think of the middle third of the Jeep as a hang point and avoid anything going down that, when possible. Gets harder and harder as wheelbase extends though, because you have to take the arc of travel into consideration when turning on the obstacle.I put a Next Venture skid on my rear diff just before heading out on the Rubicon trail a few weeks ago. I noted that I had to file the cover surface flat from the large burr rolled over from dragging the bottom. I think the rear diff gets more neglect than the front, because you can aim the front, but the rear gets the track that results from not seeing it. So, IMO, the rear diff skid is more important, unless you have a spotter on every obstacle.
