Questions about KC FLEX ERA 4 lights
DOUGCOGLEY
Doug
Prospect PA
2024 Wrangler Sahara | 2008 Jeep Liberty (manual)
  • General
    • Does anyone have these and do you like them?
    • What use cases have the yellow light assisted you?
    • What filtered did you use and why?
    • Where did you mount them?
    • What mounting hardware did you use?
  • Wiring
    • Have you connected to the Mopar Aux switches? I read you have to cut off the switches and relay.
    • What color did you connect the white lights too? Assuming the switch 1 or 2
    • What color did you connect the yellow lights too? Assuming switch 3 or 4
    • If you use these on the front bumper vs a pillar install is the wiring long enough?
