Question - please help
Carchaeologist
Vic
2021 Wrangler JLU Willys StingGray
2021 Willys JLU mostly driven on road and only one off-road trip thru Berdoo Canyon in SoCal has a squeak. After the trip the Jeep started to make random squeaks when going over uneven road / bumps (noticeable when windows are down). The Jeep needed an oil change at 7434 miles on the clock, so we took it to Russell Westbrook Chrysler Dodge Jeep Ram of Van Nuys, CA since we had three free oil changes + tire rotations when we got the Jeep new.
When we got the Jeep back it still had the noise. Few weeks later We made a second appointment took the Jeep in and after two days they said it needs new rear breaks and the parts were on order but we can pick up the vehicle till the parts arrive. At this point the Jeep has barley 8004 miles.
It makes no sense to me... specially when they sent the report during the oil change showing there were no issues with the brakes (se below).
What am I missing here........Any input would be appreciated. Thank you all.
Jeep Wrangler JL Question - please help Jeep Report
DVBenco
Waynesburg, PA
2021 JLU Willys Granite Crystal
Don’t know what kind of squeak you have, but…
Did you have the top off during the trip? Sometimes mine does the same - remedy is to be sure the bolts for hardtop are securely fastened and/or clean surface between top and Jeep body because dust and dirt in there can squeak too. I use a little wax before putting top back on and just dust off the top and Jeep before reinstalling.
FWIW, my 2021 JLU Willy’s (8800 miles) has never had any brake noise or suspension noises - if that’s where it’s coming from it’s a different story.
hope this helps
Old Dogger
Cave Creek Arizona
Brakes don't wear out in 8,000 miles. Sometimes the rears pads go at about 40,000 This depends on ones type of driving.
Squeaks over bumpy roads, would be suspension related. Or if it is a squeaky rattle, then something loose.
dpike
New Jersey
'20 JLUR 3.6
The seal around the glass in the rear hard top got squeaky on mine. I got some rubber gasket lubricant from a Honda dealer, greased them up and it went away. Now the symphony of squeaks from my dash when it's cold out is a whole 'nother story.
Carchaeologist
Carchaeologist
Vic
hope this helps
Thank you Dave, we never have taken the top off since new. I think the noise is coming from the rear I will double check and make sure all the bolts are tight. Perhaps that's a good place to start although the stealership said they checked it who knows if they really did or not.
Carchaeologist
Carchaeologist
Vic
Thank you Bill I agree with you, it would be premature at 8K hence my confusion on the stealers findings.
Carchaeologist
Carchaeologist
Vic
Thank you for the recommendation on rubber gasket lubricant, I will definitely look into this.
limeade
Guy
Reno, NV
If the squeaks aren't occurring during braking, then it's probably not brake related.
Since it began after your off-road trip, I suspect it's a suspension squeak. If you were in a real dusty/dirty area, it's possible some dirt has found it's way into a suspension joint or rubber bushing. Wash the underside really well, spraying a concentrated stream into all of the bushings and joints to flush contaminants away. Another area to clean is where the springs reside in the spring pads. Once it's dry, buy some Fluid Film and spray each joint and bushing, to include the bolts going into the joint/bushing area.
Drive a road where you know the squeaks occur and see if it's fixed.
Ohio
Subaru
We are also experiencing squeak on 2021 wrangler rear glass when going over bumps . I can duplicate noise by pushing on glass .
Bill_P
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
Just a poke here, but since the squeak started after an off road trip do you think you could have loosened anything up in your spare tire or tire carrier? Mine squeaks from the tailgate when I'm on a rough road.
JLJoy
Wichita
2024 Jeep 392, 2026 Ram RHO
I had squeaks from my rear glass. Used some dielectric grease on the seal and it is nice and quiet.
