Putco Blade LED Tailgate Light
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Really not a fan of external stick-on doo-dads, but this is actually pretty slick and looks useful.​
Think I'd like it a lot better if there was an interior option to mount it inside, either at the very bottom or maybe the top of the rear window (at least for hardtops, since that wouldn't work very well with a soft top).​
jthoms1
jthoms1
Charlotte
2020 JLUR
I’m typically of the same mind as you.
  • Like
Reactions: AFD
MayThe4x4BWU
Sam
Bartlett, IL
2023 JLURXR
LFG 😅
I like the way they used available tow connectors to integrate the wiring for them to reduce or eliminate any need cutting/coupling. Downside seems that you have to have the tow package for them to work at all?
webwbr
Chicagoland
2021 JLUR - Sting Gray
Amateur Cynic/Professional Skeptic
I want to hate this... but this may be just what I need for brighter reverse lights. All the other features are just icing on the cake.
I was planning on going with the ORACLE Lighting Rear Bumper LED Reverse Lights... but that requires the removal of the whole bumper to install. This looks tons easier.
Damn you for posting this! Now I'm even more conflicted. ;)
I hope someone chimes in with an enthusitic reason to buy it, or not.
4doorturbo
Tyler
Orlando, FL
2021 JLU Sport S
Definitely interested in these for the reverse light feature. I don't have the tow package but I would imagine it can be installed by tapping into the taillights, right?
AFD
Northeastern US
Not designed for use on Sahara or Rubicon Models - from Putco product description
Putco advises that it's not compatible with the Rubicon or Sahara because the space between the rear bumper and tailgate is slightly smaller than the sport bumper. It will technically fit. - from Quadratec (product Youtube video)
This light bar will not fit Jeep JLU Rubicon. The light bar using the provided removal clips will result with the lower portion of the light bar to be hidden by the bumper. The light bar provides 3 different modes of lighting: RED-braking, YELLOW-directional, and WHITE-reverse. The WHITE LED lights are the ones affected by the installation issue. I would not recommend this light bar for a 2018 Jeep JLU Rubicon. - from user review (at Quadratec)
Didn't realize the JL Sahara and Rubicon's rear bumper height was different than the other trims (thought they were maybe talking about the MOPAR steel bumper, but that's never been a factory option for the Sahara). So it sounds like this would be pretty worthless if purchasing for the brighter reverse lights on either of those 2 trims. Bummer.
webwbr
Chicagoland
Thanks @AFD... welp, looks like I'm back to these as my best option.
  • Like
Reactions: AFD
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
Ha! My thoughts EXACTLY!
I'd probably disable the running light circuit. The backup, and braking function would interest me.
Yzfguy
Brent
NJ
Grand cherokee , wrangler JLU Willys
I watched the video thinking "yep, I'm buying this" u til I saw that I need the towing harness to hook it up :(
JKWMD
Independence Kentucky
2022 JLU Rubicon; 2021 JLU Sahara
I like this idea, but have a JLUR, so a no go; maybe they'll come out with a Rubicon/steel bumper version? I also would like something a bit more robust for attachment rather than relying on 3M tape alone; I've been let down too many times by that stuff.
MRH512
Wrangler Rubicon JLU
I have been waffling on these as well. I'm fine with removing the bumper for installation. It just seems like so many people have issues with moisture getting into the casing.
webwbr
Chicagoland
Thanks.
Interesting... I just found that thread on the issue. I do have a plastic rear bumper, so fitment should be less of an issue than it is for the steel bumper... but the water/moisture is concerning. I wonder if they corrected that. I see Oracle warrantied the product, but the hassle of removing the bumper for each warranty replacement is unappealing.
