Led pods light wiring?
ornglj05
Hayk
2023 Rubicon JLU
I bought a pair of led pod lights for my 2023 JLU and wired it to the stock aux 3 location which 15 amps and I was wondering if should’ve wired it to 40 amp aux 1 location cause I later noticed that their 100w each pod at 12v and I can’t find anything to where it says how many amps it draws can anyone shed some light on these matter?
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
Mine are 100w each so that’s why I was asking I’ll tried to contact them but for some reason it would give me an error code while trying to them an email
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
What fuse is on the included wiring? If it's over 15 I'd consider swapping to Aux 1 or 2.
100W x 2 should be close to the 15W at 12.8V, but you don't want to fuse on the ragged edge. Just depends where they are rated.
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
The fuse included is a number 10 if I remember correctly
GATORB8
CLT NC
You'll be fine on the 15 if that was for both. They were generous with the wattage rating if it's per light, or the rating is for the pair. 100W is around 7.5 amps.
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
Thank you gator for the help I really do appreciate it.
THAW
Foster
23 JL4DrRubicon
Assuming you used the harness included with the lights, you should be safe to let the Aux 3 15A fuse answer your question; if it blows move the lights to one of the 40A switches.
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
yes so far so good haven’t had any issues with my wiring to aux 3 15 amp
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
watts/volts=amps so 100/12.8=7.8125amps
so pair will pull 15.625 amps. you're on the edge but who knows if they are ACTUALLY pulling 100watts.
OP can you post a link to what you purchased?
Did you wire them directly off the aux switch power wires?
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
Here is the link, I wired it to the aux 3 with the black wire going to negative battery terminal and red going to the aux 3 wire.
https://a.co/d/3TRwn4H
GATORB8
CLT NC
ornglj05
ornglj05
Hayk
2023 Rubicon JLU
Great that’s what I thought but I still wasn’t to sure, thanks gator.
