KC light wiring
Yzfguy
Brent
NJ
Grand cherokee , wrangler JLU Willys
I have a pair of flex 3 lights coming soon. I don't have aux switches, so I will be using the supplied wiring harness and switch.
Can someone please tell me how you hooked these up to power them? There is a backlight wire and a main light wire. I'm assuming I tap into a fuse so that they go off when the Jeep is shut off? I'm hoping someone can show me exactly where you hooked up.
Thanks! I know I'm jumping the gun, as I haven't even seen the instructions yet, just trying to get the install straight in my head :)
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
The instructions will have a super clear diagram of how to hook them up with the supplied toggle switch.
Yzfguy
Yzfguy
Brent
NJ
Splicing involved?
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
Splicing involved?
Should not be if you are not adding them as reverse lights or as you mentioned you are not, adding them to the aux switches.
You will need to now feed the wiring through the firewall though to Mount the supplied switch inside the cabin.
