Proper Offset & Backspace Help Needed Please…
Whaler27
Alex
Oregon
Saving the world :-)
Se
Note a 9” wheel is 10” wide, so 0 offset is 5” BS.
See diagram and table included above for clarity.
TheBirdie72
Rhode Island
2021 Jeep Wrangler Freedom Edition 2 Door
It sucks where I live, having tread outside the fender will get you pulled over and a failed inspection. Definitely limits offset options.
I have 4.75 backspace / -6 offset on my sport with rubi takeoff suspension. Tire poke of about 2 inches on 17x9 wheels which I like - very stable handling. But this is just covered by the fender flares I put on, so no inspection issues. ? So there are options if you are in a PITA inspection state.
Before vs after:
Jeep Wrangler JL Proper Offset & Backspace Help Needed Please… 92942696-C738-486B-AFF5-A17A8BCEC7BA
Jeep Wrangler JL Proper Offset & Backspace Help Needed Please… 810BD580-341D-4ED1-A111-033A845E4871
Jeep Wrangler JL Proper Offset & Backspace Help Needed Please… 1C41C2CA-40DC-45FC-A408-5730CAFF7320
KHR Racing
Robert
Hawthorne, Ca.
2022 Rubicon Wrangler
Before vs after:
……………….. so if I go with 3 1/2 inch backspace that means the tire will stick out 1 inch more ( past the fenders ) than a 4 1/2 inch backspace would………..Is that correct? Thanks.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Use this https://tiresize.com/wheel-offset-calculator/
Stock is +44 mm offset, 285/70R17
Careful comparing your Rubi to a non Rubi, different width axles and fenders.
Rangemaster
Nevada
2020 JL Rubicon Diesel
Business Owner
2022 rubicon two door…. Going with 37×12.5 tires and 17× 9 wheels….. what is the backspace and offset that is needed….. Also will I need to run spacers? Thank you very much for your help.
3.5 inch backspace if you want to do full flex, do not listen to these guys. Anything less will get you full rub. I am running the same rim and tire, and I do not get any rub in full flex.
GATORB8
CLT NC
Regardless of what you end up choosing, bump stop extension is what will establish your clearance. I’m not sure what comes with the TF kit, but some kind of adjustable bump without removing the front springs is nice. Whether that is 1” increments like the MC or some kind of air bump.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Here's a conversion chart:
OFFSET CONVERSION CHART
MM OFFSET TO BACKSPACE IN INCHES
BACKSPACE​
3.25"​
3.5"​
3.75"​
4"​
4.25"​
4.5"​
4.75"​
5"​
5.25"​
5.5"​
5.75"​
6"​
6.25"​
6.5"​
6.75"​
7"​
7.25"​
7.5"​
7.75"​
8"​
8.25"​
8.5"​
8.75"​
9"​
9.25"​
9.5"​
Wheel Width​
5"​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
5.5"​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
6"​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
6.5"​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
7"​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
7.5"​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
8"​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
8.5"​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
9"​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
9.5"​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
10"​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
10.5"​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
11"​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
11.5"​
-75​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
12"​
-81​
-75​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
This chart needs to be the first thing anyone sees in the tire & wheel section.
KHR Racing
Robert
Hawthorne, Ca.
BACKSPACE​
3.25"​
3.5"​
3.75"​
4"​
4.25"​
4.5"​
4.75"​
5"​
5.25"​
5.5"​
5.75"​
6"​
6.25"​
6.5"​
6.75"​
7"​
7.25"​
7.5"​
7.75"​
8"​
8.25"​
8.5"​
8.75"​
9"​
9.25"​
9.5"​
Wheel Width​
5"​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
5.5"​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
6"​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
6.5"​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
7"​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
7.5"​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
8"​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
8.5"​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
9"​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
9.5"​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
10"​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
10.5"​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
11"​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
11.5"​
-75​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
12"​
-81​
-75​
-69​
-63​
-57​
-51​
-44​
-38​
-32​
-25​
-19​
-12​
-6​
0​
6​
12​
19​
25​
32​
38​
44​
51​
57​
63​
69​
76​
Thank you for the chart!
