swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Google Data Center Maintenance Program Manager
Ordered the Maximus-3 rack today. Should be here in a couple weeks.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
In the mean time... GPCA Grab Handles....
Jeep Wrangler JL Project SWAMPCAT IMG_20180609_144325
Jeep Wrangler JL Project SWAMPCAT IMG_20180609_111617_618
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
CMM Offroad A-Pillar Mirror Mounts and 1-inch Ball Mounts...
Jeep Wrangler JL Project SWAMPCAT IMG_20180611_220647_186
Jeep Wrangler JL Project SWAMPCAT IMG_20180611_220647_185
anotheraznguy
Tracy California
Mojito JLUR
So, was interested in your suspension setup but had some questions for you. It appears you used the 2-3" falcon shocks with the MC game changer
I can see in the rear you are using 4 bumpstops, is that due to tire contact or is that due to shock travel?
Sadly, i can't see how many bumpstops you have up front. but same question is it due to the tire contact or is it shock? Any issues overextending the falcons?
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
I've got 4 stops in the rear, and 3 in the front. In both cases it's for tire clearance.
In the rear, even with the 4 stops, I get a little rubbing on the driver's side at full stuff on the little section of the inner fender liner that sticks out.
I haven't seen any indications (yet) of hitting the limit of shock travel, but with the stops, I'm only concerned about this for down travel. If I have issues there, I'll just throw on some limit straps.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Maximus-3 rack came in Friday (super-fast shipping)!! Installed it yesterday. Will post pics tomorrow (at work all day today).
Namib
Arizona
My Metal Cloak should go on this week with the Rocksport shocks.
Where does it rub? I know the plastic pieces in the back is an issue, but anywhere else? Also doing 37x12.5s
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
First off, you're going to love this lift!
To answer your question, I've only had rubbing at that one spot in the rear inner fender liner. It's worse (read: happens more often) on the driver's side than the passenger for some reason.
Namib
Arizona
Thanks. This is in line with my expectations. I have a new rear bumper as well so that piece will probably come out.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Maximus-3 / Rhino Rack roof rack installed.
Jeep Wrangler JL Project SWAMPCAT IMG_20180912_112706
Jeep Wrangler JL Project SWAMPCAT IMG_20180912_112645
Jeep Wrangler JL Project SWAMPCAT IMG_20180912_112631
Jeep Wrangler JL Project SWAMPCAT IMG_20180912_112545-EFFECTS
Jeep Wrangler JL Project SWAMPCAT IMG_20180912_112534
TX_Ovrlnd
CStat, TX
'22 Zilver JLURD
freethinker
The rack looks great on the Jeep, the cut up headliner would drive me nuts until I came up with some kind of boot to cover them. How much effort does it take to remove if you want to go topless?
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Yeah, I wasn't to keen to cut up the liner, but since then I've not noticed it. It's not an eyesore to me.
Going topless requires some effort. It's 10 extra bolts to pull. According to Maximus-3 you could use the rack to lift the top off, but they don't recommend storing it suspended by the rack. I can confirm that a Top Lift Pro will not support the combined weight of the top and the rack.
For me, it all boils down to too much hassle to warrant taking the top off.
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
Front Runner quick release tent mount and CVT Mt. Rainier Summit Extended Stargazer RTT....
Jeep Wrangler JL Project SWAMPCAT IMG_20180915_163212
Jeep Wrangler JL Project SWAMPCAT IMG_20180916_125540
Jeep Wrangler JL Project SWAMPCAT IMG_20180916_125551
swampcat14
swampcat14
Midlothian, TX
www.c4x4.com
