Problems figuring out how to replace light bulb in tail light
DangBruhY
Aaron
2020 Wrangler Sahara Unlimited Altitude
I can't find manuals, YouTube videos, or anything on how to change the bulb.
Anyone have a clue?
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light Taillights2
FINN 2.0
Larry
Carbonado, Wa
2021 JLUR. 1979 Ford 150.
I noticed on my 2021 that there is a pop out plastic access panel on the inside that I assumed was for accessing the taillight but haven't tried it yet.
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
Deleted User 38384
Anyone have a clue?
Really easy to do, I did mine a while back, took about 15 minutes per taillight, super simple!
Jeep Wrangler JL Tail Light Bulb Replacement
Be forewarned, I have the (non-LED) halogen bulbs from the factory, however the rear tail light side marker light is an LED which cannot be replaced without replacing the whole assembly. The backup bulb and the turn signal bulb can be replaced. You will need to make sure that the bulb is a little bit shorter. I had issues where my replacement LED backup bulb was too long, and had to buy a different one to make it fit.
Best of luck, it's a very fun and easy project! ?
AdamG
Adam
SE Michigan
2019 JLSportS - SOLD; 2026 Moab 392
This is the single bolt and what the back of the light looks like when it comes out. I broke mine out on the trail, slid into a tree. That plastic bolt-spring works by compression and sucks the assembly into the body, so go easy on it removing and installing.
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light 9528AE99-2144-4E62-B95A-C26771308784
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light 6222B5F5-2099-44C0-8A89-71706F50E6A6
Ormond Beach, Florida
Retired at 55 ..
@DangBruhY
There is no way to replace the broken red lenses or a faulty LED board on a JL's LED tail light. You will need to replace the whole tail light.
Factory Led tail light:
For a replacement tail light, do look to forum classifieds, eBAY, FB Marketplace, etc. for pull offs that guys/gals are trying to sell.
Also, you could go with an aftermarket tail light offering.
With a Halogen, JL tail light, yes you can do a bulb change but the red lenses in not replaceable.
Factory Halogen tail light:
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light s-l1600
If you break the white plastic screw with the spring that secures the JL LED or halogen tail light, the Mopar part for that is... Taillight white spring screw: Mopar (06512356AA)
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light 06512356aa
If you break the black plastic bracket that is fastened onto the back of a JL, LED or Halogen tail light that part # is Tail Lamp Bracket - Mopar (68307139AA). This bracket is used on both left and right tail lights.
Jeep Wrangler JL Problems figuring out how to replace light bulb in tail light asdf
DangBruhY
Aaron
@Rhinebeck01
Thanks. I've gotten the tail light completely out and everything off. I just couldn't get to the final step of getting to the lights. Now I know why. Why does Jeep make the reverse lights so dim? I have to use the brake lights to be able to see what's behind me, on the camera.
Retired at 55 ..
@Rhinebeck01
If you have a trailer hitch, do consider ordering the HitchMount LED Pod Kit.... this terrific aftermarket b/u light offering that @Diode Dynamics has come out with is something else..
The USA company offering is well designed, decent to look at and very very easy to install for most any guy or gal.
Takes less then 10 min. to install. Also, the price point for this offering is very good.
Do read through this whole thread:
https://www.jlwranglerforums.com/fo...unt-led-pod-kit-the-best-5-minute-mod.103255/
Byrds8
Oracle also makes lights that can fit where the reflectors are in the bumper and tap into the reverse lights. IT does provide more light. Not enough to make the camera look much better though.
DangBruhY
Aaron
Other than new housings, what would be a good option?
Byrds8
I think it would be more helpful if Jeep put a better camera in to begin with. My 2016 and 2022 Silverado had a MUCH better camera for night than the Jeep.
