Bradley
- Brad
- Jul 28, 2017
- Cleveland, Ohio
- 2015 Ford Explorer
I'm not sure if anything like this exists out there or not... but would it not be possible to insert a small rubber insert into the front part of the gutter that extended over the length of the front door? Any water would then simply bleed off over the edge of the "drain" and run down the outside of the door. You could also have the gutter invert at a slight incline towards the back but this wouldn't work if your Wrangler was at the slightest angle tilting forward.
