Power Steering Fluid?
CarbonSteel
I plan to dump the factory fill at no more than 20K. What are you gals and guys using for PSF? ATF+4 or something different?
Bearded_Dragon
FL
2018 Mojito! Rubicon
I used Mopar's 68088485AB
VNT
Maine
SRT Challenger, 2015 Hemi Overland, 02 WJ 4.7, 2000 Durango, PT Cruisers, 2018 Punkn Sahara 2020 OB Rubicon
how does one flush the PS, has to be a low pressure line back to the pump.
would use the mopar fluid, since it is special for the pump
CarbonSteel
CarbonSteel
I typically do the "turkey baster" method a few times over the course of a few days.
VNT
Maine
I find the low pressure return, undue the clamp. shove a barb into the hose and add a section on the other end and put into bucket, start up and run 20 seconds,while turning wheel. shut off and top off reservoir, repeat until flushed, reconnect.
just not familiar as yet, will crawl under and devise a plan.
