Power Steering Fade
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
Did a decently long and obstacle filled trail yesterday and had a lot of power steering fade throughout the day. Diesel Rubicon with a 3.5 lift on 37’s with stock steering and stock linkage. Short of going to a full aftermarket steering system does anyone know if there are small improvements that can be done before I get to the point of a full upgrade?
jadmt
jeff
montana
did your steering overheating warning light go off? I have been to Moab 3X's in less than a year and the first time I was my pizza cutters 35x10's second time 35 MT's and last time 37 ats'...did several of the same trails with each and temps were very similar....for some reason with the pizza cutters my power steering kept overheating and I had the warning light on a lot...I was worried that I would have the same issue with the 35MT being much more aggressive and the 37's but never had it come on a single time....I am guessing the heavy diesel probably makes a difference on steering.
flick2614
flick2614
Randy
AZ
Grayhound
Michigan
Jlurd
I looked at boost kit as an option; how hard was it to install on the diesel?
It’s not difficult per se but it is tight. Pulling the pump wasn’t a big deal, but installing the cooler was a hand cutting adventure. So tight and hard to manipulate things. Apex video does a good job of setting the expectation.
roaniecowpony
Retired Engineer
I'm running the Apex boost kit w/cooler for about a year or so now. Good interim step for those not wanting to go to a hydro-cylinder. Personally, I think 37s and HD steering draglink/tierod equipped JL that plays in the rocks heavily, should have a cylinder. That's where I'm going.
flick2614
flick2614
Randy
AZ
I didn't know there was a steering overheating light so no. I would assume fade would be because it was heating up but really don't know how to check temps.
jadmt
jeff
montana
yes you get a warning light and a message and it says something to the effect of your power steering is overheated and you may have difficulty steering or something like that...you can still steer you just have use more muscle....
Grayhound
Michigan
Jlurd
I’ve not ever gotten the message but I’ve had mine feel like there was no power assist when I’m stopped on rocks and needing to turn without moving forward
roaniecowpony
Retired Engineer
If your steering system isn't overheated and you're having difficulty steering in the rocks, with large tires, aired down, it's often just exceeding the power of the steering system due to the tire position. This is where all the steering mods are founded. High pressure boost (Apex) kit, coolers, bigger steering boxes, hydraulic cylinder assist, etc..
Grayhound
Michigan
Jlurd
That’s why I did the apex boost kit!
roaniecowpony
Retired Engineer
Grayhound
Michigan
Jlurd
I can see that. I’m only on 35s and have the issue. I can only imagine of I went large I’d need to do something more.
