Parasitic power draw?
SIxSixRider
Ken
South Carolina
2021 Wrangler JL Sport Unlimited
I posted a loss of electrical power on my ‘21 JU a week or so back & got some good info. I bought a jumper pack just to get me home & started troubleshooting. It SEEMED as if the battery was bad or not holding a charge. I had it load-tested at 2 different AutoZones….one said it was good & the other said it was marginal. Since I felt it was suspect (& despite being only ~2yrs old) I opted to replace it (went from 600CCA to 850CCA) so I was certain it was dealing with a good battery. I also checked engine codes & cleared it - only one: “P0562 - system low voltage”)…not surprising given the (seemingly) dead battery. I also opted to do a power draw test on the negative side of the battery with my digital multimeter. When initially connecting the leads & the Jeep off, the draw was ~5amps but the radio & dash display were still illuminated. About 40sec later & the displays now dark it dropped to ~1.7-1.9amps. At about 5.5min it dropped to ~0.2amps. And at about 10min it dropped to ~0.1amps (100mA). It never got lower than 0.1amps. I pulled every fuse 1-by-1 and it was still ~0.1amp. Is this too high? I’ve read that it should generally be <50mA and in newer vehicles it can be 50-85mA…which I’m close it. I also read that sometimes newer vehicles can take 45min or even longer to fully shutdown their electronics. I’m concerned that a parasitic power draw MAY HAVE led to the premature failure of my original battery & COULD now be nibbling away at the new one. Thoughts??
SIxSixRider
Ken
South Carolina
You replaced the main battery without also replacing or deleting the alt?
My JL has an eTorque battery underneath….no AUX battery.
