Paint Corrosion
MichellePeters
Michelle
Michigan
2019 JLU
@JeepCares I purchased my 2019 JLU new and the extended paint coverage warranty will be expiring next month.
I’ve had it in for paint repairs twice already and just found a new spot. I’m concerned that this is going to continue and I’m not going to be able to afford to fix it in the future. They have only done spot repairs at the certified Jeep dealership In taking it to and aren’t doing total repaint on the pieces. I’ve had spots repaired on all four doors, right front fender, hood left and right and now there’s new corrosion on the tailgate. Are there any conditions where Jeep will repaint the entire vehicle?
I’ve even considered selling it to get a new one but there isn’t verification that the corrosion won’t happen on the new vehicles. It would break my heart to sell it, but I can’t afford to fix corrosion if it continues to happen. Please help!
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
Pictures would help.
JeepCares
Auburn Hills, MI
JL
Hi Michelle,
Thank you for the tag. We cannot guarantee cost assistance once your vehicle is out of warranty but if you send us a private message, we can connect you with a case manager who can provide you with extra support alongside your dealership appointment.
Blair
Jeep Cares
autotragic
the cornbelt
'21 JLR 6MT
Hi Michelle,
Blair
Jeep Cares
Look Jeep cares so much that they didn't even bother to read the post that said it's still under warranty and went straight to telling you you're not under warranty. Shocked, shocked I tell you.
kah.mun.rah
Merenkahre Jr.
Duat
Maybe that is why they said, "once your vehicle is out of warranty" and not "since your vehicle is out of warranty." Them offering a case manager through a PM one business day after the original posts seems pretty impressive to me.
ScoutII
Billy
Denver, CO
2007 Jeep Wrangler Sahara, 2019 Jeep Wrangler Moab
. The current warranty policy is to replace the doors not repaint, especially with corrosion at the bottom of the door. Too many reoccurrence issues with repainting
Only-In-A-Jeep
North Georgia Mountains
2021 Jeep Wrangler Sport
Does anyone know when the issue was supposedly resolved at the factory? I have read that at some point in 2021 new Jeeps were shipped out that would not have this problem. Is that true?
JL ME
JOHN
Portage Wi
2021 JL Willys ,2006 Roadking , 2008 Hayabusa
Industrial Maintenance
The late 21 and newer jeeps have a barrier or plate of some kind between the hinges and body panels that is supposed to stop corrosion. but it still happens just not as often or as soon.
I have a late 2021 Willys and just noticed a small spot on the driver's door upper hinge. Right in the middle of the hinge.
Smoke ‘Em
Tyler
KS, CO
2019 Wrangler JLR
The late 21 and newer jeeps have a barrier or plate of some kind between the hinges and body panels that is supposed to stop corrosion. but it still happens but not as often or as soon.
Sadly I don’t think the barrier plate makes a lick of difference. My 22 JLR has it along both sides of the hood. Looks to be the same crap that afflicted my 19 JLR. If I knew for 100% certain they’d fixed whatever the hell the problem is, I’d just order a new one….but I have zero faith in stellantis to identify the problem, let alone actually implement a solution. When it bothers me enough to do something on my 22, I’ll strip it down and have the entire vehicle Line-Xed.
JL ME
JOHN
Portage Wi
I hear ya. The hood corrosion has nothing to do with hinge barrier working or not working. That was just shitty prep work before they painted it.
TheNewGuy
Wes
NH
2021 Jeep Wrangler Sport S 2 door
I don't believe '21s have the new hinges. I have an Oct '21 build and don't. The TSB was released in 2/23 so I'm pretty sure they cut in the new hinges around that time frame. I would say late '22 at the earliest.
mgroeger
Southern UT
2021 JLUR 2.0T
Do you happen to have that TSB handy? Also is this covered independent of how many miles are on the Jeep... i.e. out of warranty?
GoatHerder
Michael
Illinois
Jeep Wrangler JL Rubicon Recon Wrangler TJ
My plan, as the paint gets worse, the build gets more extreme.
Sierra Hotel
FL
2020 JLUS
Retired 😎
I've attached the most recent TSB, as well as a warranty service bulletin that further clarifies that if hinges are replaced on a panel (door, tailgate), they both must be replaced.
Please note that replacement of a panel is not a given under the TSB unless the corrosion occurs in the hem flange area (See bottom of page 2).
TheNewGuy
Wes
NH
Warranty is 5 years unlimited miles
