Tank the Jeep
- Greg
- Oct 31, 2019
- Charlotte NC
- 2020 JL Rubicon Diesel
I just got Tank back from getting the door hinge corrosion fixed. I got to talk to the body shop and learned a few things. This was a warranty repair that I took to Gastonia CDJR in NC. They had Tindal Ford’s body shop do the repair. The body shop said the was not a recommended fix from Jeep. No procedure no parts to prevent it from happening again, they looked for it. He said that on the first one they were surprised to see the bare metal hinge was mounted directly on the bare aluminum door skin. BTW, the hinge is not steel or at least ferrous because a magnet does not stick. Anyway, the body shop took all four doors off and took them apart. Repaired the corrosion, painted the area under the hinge and placed a film under the hinge. He did not describe the film. He did say they stand behind their work and if there are anymore problems to bring it back.
The body shop is getting a lot of these repairs. There were four more jeeps lined up behind mine. He said Pacificas and Explorers are seeing similar corrosion on the hoods. I’m not sure if Jeep has fixed later years but us early JL Jeepers will get this corrosion. Just a matter of time. I still have my hood and tailgate un protected.
The paint and film repair got me thinking. What if we apply spray plasti-dip between the hinge and the aluminum. Basically unbolt one side of the hinge, spray, let dry and bolt back. The overspray can then be cleaned up by peeling. That will leave a sealed film between the hinge and aluminum. Spray the panel and the back side on the hinge should leave a few thousandths gasket in between.
What do y’all think? Would that work?
