P0137 - Zero Volts O2 Sensor
58Willys
Geoff
Western Washington
2018 JL Sport
Happy 4th Everyone!
2018 3.6L - Couple of months ago I had an oil leak on rear of Bank 1 valve cover, fixed it all good. A few weeks later got a P2096 and P 0171 codes. Installed new Bank 1 downstream O2 sensor, all good. Yesterday got a P0137 code. No oil leak now, all clean. Checking live date, I have zero (0) volt reading on Bank 1 Sensor 2 (downstream).
So do I have a bad O2 sensor, or a wiring issue? I'm thinking a wiring issue as one screen shot of live date had .21 v, and the rest had zero, so a bit intermittent. I have the wiring diagrams, but haven't been able to find to O2 diagram yet; anyone know what the power wire to Bank 1 downstream sensor is? Bad ground?
Any other ideas?
Thanks!
Jeep Wrangler JL P0137 - Zero Volts O2 Sensor Screenshot_7-4-24
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Did you use an OEM O2 sensor? Make sure it is plugged in still, and check fuses.
Florida Man
New Mexico
Jlur 2023
Use oem o2
Also if oil got on the sensors they are gonna go out over time. I had two get ruined from a dealership oil spill
58Willys
58Willys
Geoff
Western Washington
2018 JL Sport
Used a OEM sensor, one of the white signal wires is bad. Waiting on new one.
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
I've had to replace o2 sensors on practically every vehicle I've had, they don't last forever. I would replace the sensor while I'm in there
