Outside Temp reading & Compass
larrynjean
Hesston, PA
2018 Wrangler JL Sport
I noticed yesterday when the outside temp was 95 my JL said it was 79 even parked in the sun...
Also the compass changes from N to S to E to W when not even moving...
Anyone else seeing this problem???
brewcrew
Hagerstown , MD
JLUR Punk'n
I have had this issue a few times. Have you found a solution?
WXman
Central Kentucky
Not to sound stupid, but you do realize that the outside ambient temperature display only updates itself after you've been driving a certain speed for a certain distance, right? Just wanted to make sure.
Yes if you've been driving down the road for a while and it's still doing that, you may need a new sensor. They're a breeze to swap out behind the grille.
brewcrew
Hagerstown , MD
JLUR Punk'n
Thanks for that info. Unfortunately, I have had a few times that it was stuck at one temperature after several hours on the road. Sounds like i need to replace the sensor.
larrynjean
Hesston, PA
For the compass there is a recalibration setting in the compass menu...You need to select recalibration and YOU also need to drive in circles until it displays calibration complete...
My temp. setting seems to have fixed its self???
BillyHW
CAN
Wow, we can't even trust the temperature reading now?
charitysteve
Simi Valley
JlU Rubicon
My outside temp is saying 185 degrees and my ESS is now not working. Anyone experience that?
Djmatt85
Daniel
Sacramento, CA
18 JL Sahara
Not sure where the temp sensor is on the JL, but sounds like the sensor wiring is broken. When it’s that hot, it may not allow ESS to function.
A lot of BMWs have the sensor in the underbody panel in front of the front tire. They’d get ripped of by pulling too far forward over parking blocks and cause the same issue.
Chocolate Thunder
Jeremy
Just because you Jeep is capable of going everywhere doesn’t mean that you should. Sounds like you are driving straight into the earth’s care toward hell. Turn around and go back!
ZeroTrev
Trevor
colorado
2018 JL
This happens to me sometimes too. I'll turn my auto start when it's super cold but I still get in a cold Jeep since the thermostat says 51. Quickly drops once I get in though, but due to it thanking it's hot no seat or steering wheel warmers turn on. It never got above 51 on the days it does it and it always seems to be 51 when it does this.
Kallico
2019 Wrangler Sport S JL
Im stupid or something - how exactly do you get to the calibration menu for the compass?
Stuweeks
Stuart
Nashville, TN
2018 JLU Rubicon
I’m having the exact same problem. Mine even says 50 degrees when it’s 25 out. Really makes me mad bc I bought the cold weather group specifically for that purpose since I park outside and it doesn’t work. Anyone have a fix? I feel this is unacceptable.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
If you thought inaccurate temperature sensor was unacceptable, you’ve seen nothing yet.
Stuweeks
Stuart
Nashville, TN
2018 JLU Rubicon
Oh I have. My first JL was a lemon and I had to get it towed the night I bought it. I think it’s unacceptable they sold me a Cold Weather Package to heat my Jeep prior me entering and it doesn’t work.
