Oracle Lighting Reverse Lights Manual Operation
dav7922
Corinth, MS
2021 Jeep Wrangler Unlimited Rubicon JLUR
I installed the Oracle Lighting Reverse Lights that are designed to fit in the reflector location on the JLUR rear metal bumper. I purchased the wiring harness to ease the installation. Not sure that it made a big difference in ease of installation. Probably wouldn't order the $25 harness again. Anyway, the lights work great and are what I had hoped for. The indentations on the metal bumper were not the exact same size. One reflector popped out easily. The other reflector must have been hammered into place because I had to break it to get it out of the indentation. The install of the reverse lights was the same. One went in easily and the other one had to be lubed up and gently hammered into the indentation with a soft rubber mallet. They work great when you put the Jeep into reverse.
I want to know has anyone wired them this way plus wired them to the Auxiliary switches on the dash? I would like to operate the lights without having to put the Jeep into reverse or having the motor running. Please share with me what you may have done. Can you have it both ways?
ORACLE Terry
Peak Sponsor (Level 2)
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
Those reverse lights are very bright for sure. For this most part if you use the aux switch, it either has them on or has them off and then the revers light would work when in reverse only when the aux is on. I'm sure there is a way to run some kind of modification to that.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Do you happen to have a wiring diagram for the Oracles? I can help you figure it out.
Here's the stock wiring:
Jeep Wrangler JL Oracle Lighting Reverse Lights Manual Operation 1724073803363-zx
GATORB8
CLT NC
Alright, looks like Oracle kept it nice and simple, looks like you are pulling power and ground from the driver tail light. LEDs have relatively low draw so that's definitely the easy answer to the intended operation:
Jeep Wrangler JL Oracle Lighting Reverse Lights Manual Operation 1724075128706-5n
The stock system triggers with positive from the BCM, so you have a standard ground you should be able to use for both triggers.
It would appear the BCM is just using an onboard relay, so I wouldn't expect it to be monitored for outside power (or have an issue with outside power), so, really you can just connect the Aux switch to the positive side of the circuit.
One issue with this, is that you will be lighting up your driver side reverse LED in the taillight if it's not separated. To prevent that, you should be able to add a diode to the connection between the tailight and the aux splice, making that a one way circuit.
GATORB8
CLT NC
dav7922
Corinth, MS
Thank you both for your responses. They are very informative. I will try it soon and update the thread.
Grayhound
Michigan
Jlurd
Out of curiosity, do you have a Tazer?
I used the trailer harness to tap into so when i try the 5 unlock presses my reverse lights come on but not my oracles due to using the trailer light for reverse.
dav7922
Corinth, MS
I don't have a Tazer at this time. Sorry I can't provide you any information.
