Oil pressure spikes
Doomgaze
PA
2018 JL Rubicon Unlimited
I'm aware oil pressure sounds go up some during high rpms, but I'm wondering if others are getting the same values. I idle at about 30, and it stays close to this until I hit the gas hard and go over 3k rpm. Then it jumps up to about 70. It goes back down to 30 when I let off the gas. It's basically either 30 or 70 depending on gear/rpm.
Tharsis
Tyler
Iowa
2018 JL Rubicon, 2008 Ford Ranger
That's what mine does. It's normal for the oil pressure to go up when you put the engine under load.
Rockreid
Rocky
New Canaan, CT
2018 JLU Jeep Wrangler Sahara
A usual component in an engine is called an Oil Pressure Relief Valve. This valve will open when oil pressure reaches a certain level allowing oil pressure to drop and to maintain proper pressure range. I bet this is what you are seeing in action.
roaniecowpony
Retired Engineer
The pentastar has this 2 stage pressure control by design.
