MagnusWolf89
Hello, wanted to ask what kind of oil pressure are you guys getting at idle after you drive your jl wrangler with a 3.6L for a while. Mine usually will stay at 30 to 31 psi while cruising and will be at 29 psi at idle until the engine oil temp gets over 200 degrees, then it will drop to about 27 psi and sometimes 26 psi after sitting and idling for a long time. Worried 26 psi may be too low. I use a mopar oil filter and amsoil signature series 0w-20. The jeep is also a 6 speed manual.
