Oil Pressure, Coolant, Trans Temp, Oil Temp?
NewbJLUOwner
JLU Rubicon Diesel 2022
Hello All
Please don't hammer this newb to hard
New to Jeep World, 2022 JLU Rubicon Eco-Diesel owner
Owners manual doesn't list what the guages should read, under normal operation
I understand basic readings such as Tire Pressure, Battery Voltage
What should the Oil Pressure, Coolant Temp, Trans Temp, & Oil Temp read??
I would like to keep on eye on these guages occasionally and have no reference
Any advice appreciated
Bob Burd
Bob
San Jose, CA
www.snwburd.com
Oil pressure is easy - 30 when rpms are less than 3,000, then it jumps to 75psi above 3,000.
The others depend on load. Highway cruising i see temps less than 200F. 10-20F lower for trans. As load increases or slow speeds on trails, I see them climb about 20-30F. Fan kicks on to drive coolant temp down when it reaches around 225F. Fan drives it down to about 212F before turning off.
NewbJLUOwner
NewbJLUOwner
Most helpful ?
Thanks much ?
