Ohhh no.
KDB
WI
2018 2 Door JLR
Or rather, lack of....
Agreed, it looks minuscule but still appears to have a front diff? But know that you have me thinking about it I guess even a 4 x 2 would need a front differential on a solid axle to allow for independent wheel spin, correct? Or am I missing something else?
Sean L
Sean
North Carolina
I don't know the exact mechanics of the front of a 4x2 Wrangler, but there shouldn't be anything connecting the front wheels to each other. Its probably just a metal tube in place of an axle with no drive line components so it can use the same suspension as the other wranglers.
cbrenthus
FL
'19 Mojito JLUR
4x2s do have a beam connecting the front two wheels. It's much easier to put a dummy axle in place of the true axle so that all of the hardware lines up, then re engineer the entire front of the vehicle. I know my 2003 FWD sentra had a beam "axle" in the rear connecting both wheels. A beam axle is just that, a beam, and both wheels are bolted to the ends but they are not connected to each other as far as movement. Here is a link to a 4x2 XJ front beam, I'm sure the wranglers have something similar:
https://www.ebay.com/itm/00-01-Jeep...eam-NO-ABS-J12-/292995108861?oid=362549265840
I checked out an old pic of my JKU passenger side, no trail rated badge, and I don't think I removed them, so I believe that.
InvertedLogic
Denver, CO
20 JTR
Nope, the wheel just spins on the wheel bearing, no need to connect the two wheels. This axle is called a beam axle. You see a similar set up on most semi trucks.
AbeWay
Abe
Wyoming
2018 Jeep Wrangler Sport S
First thing I'm planning on doing is installing a rear diff lock. Would solve this problem quick.
Niteshooter
Toronto Canada
86 Jeep CJ7, 86 T-Bird Turbo Coupe, 00 Saturn, 10 smart, 11 JK
It does look like there is a front diff. Which begs the question why did he not shift it into 4wd..... :facepalm::facepalm::facepalm::facepalm::facepalm::facepalm::facepalm::facepalm:
Jeep Wrangler JL Ohhh no. diff
