Officially done.
TaiMc
Tai
Houston, TX
'18 JLU Sport Mojito!, 3.6L & '18 Ninja 400 KRT
Communications Manager
Thank you! Theoretical (and some days applied) Strategist actually. Does your Houston location suggest an astro... focus for you?
Haha, I knew it! I work with Mathematicians daily. I know how yall minds operate! ?
Yes! I’m a native Houstonian.
Go Astrosss! ???
jellis4148
Missouri
So, I realize you seem to know what you're doing as far as Suspension geometry goes and setting the Jeep up. You might consider going back to the stock knuckles and ball joints. Maybe even consider removing some things and putting them back to stock that you don't need. I'm sure you've had/seen brand new parts be defective. You might have something you've added that was cast wrong, or in bad shape from the get go. Hope you fix it. I mind is a terrible thing to waste on a Bronco, lol.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
I think the DW is part of life with solid front axle vehicle. My 2018 F250 had this issue, so does my 2021 F350 Dually. Have less than 5k miles on Dually and it happened a few times.
Respectfully have to disagree. I've had a couple of CJ-7's, an '85 GMC, a '22 F350 (12k miles), and my '22 JL Willys. Never once experienced death wobble or anything close.
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
The Jeep is currently in my back shop until Spring. At that point I will sell it, fix it, or burn it.
Dadawada
Barrett
Raleigh, NC
2018 Rubicon Unlimited, 2020 Honda Goldwing Bagger
Network Technology Executive
I'm curious what mods you had done. I've had my 2018 JLUR for 4 years now. Only mod I did was installed 35" tires. It drives great and always has. No issues with steering or suspension.
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
it would be a shorter list to say what is not. Gears.
Clayton arms
2.5 springs
Dynatrac ball joints
Reid knuckles
2.5 ton Rusty’s stering
Apex steering boost
Steer smart track bar brace
35” Toyo at3
Fox DSC 2.5 shocks
Fox ats stabilizer
I’m sure I am missing stuff
NewJLU2019
Curtis
2021 Rubicon Unlimited 2019 Sahara Unlimited
Welp. You are def belong in a bronco if you think they even begin to compare with jeeps... so enjoy your new bronco- buy a rain coat for the leaks, and superglue for the dash- it'll be fineeeeee ?. Bye felicia.
Hello Red found you some hot sauce you might find to your taste. My daughter found it at a Fall Festival here.
Hot Sauce - Lalos Sauce
Jeep Wrangler JL Officially done. 688243342
entropy
Foothills of the San Gabriels
OF top 1% content creator
Well after 2 years of fighting with this thing, 1/2 a dozen gear boxes, track bars, stabilizers, tires,wheels, control arms. I’m done fighting it. Yesterday doing 70 on the expressway I hit a small bump, Jeep literally went across 3 lanes of rush hour traffic, over the curb and into the grass shoulder. Couldn’t get the death wobble to stop. Im shocked I didn’t hit anyone or cause a major accident,I’m done. I’m going to see what I can get for it the way it sits, if I can’t get any decent offers there will be a ton of parts listed in the for sale area. I have never fought a Jeep this much in my life.
I hate to say it but there will be a new Bronco sitting in my garage before long.
That's insane. Death wobble should not actually throw you around like that unless you panic. What you experienced was some bizarre mechanical failure.
Whatever it was, and if it was related to death wobble or not. I would also move on.
Northernlites
North
Jeep
Reminds me of back in the mid 1970's and early 80's when short box trucks were the rage. Ford, Chevy, and Dodge. Just about everyone had lift kits, multiple added shocks, and big rims/tires. Didn't take long for transmissions, transfer cases, suspensions, steering components, and axles to start to fail. Even low mile trucks. Now with all the technology and lighter components on new vehicles, some were just meant to stay basically stock. But there are always the lemons from every auto/truck manufacturer in the world. Knock on wood I never had one yet.
entropy
Do you think it’s more common on jeeps with Frankenstein suspension systems where different manufacturers may have slightly different tolerances that cause wear on each? combine that with larger tires? Just trying to figure out the common denominator.
Having springs from one manufacturer, shocks from other, and control arms from other wont fuck up your Jeep. Unless you are spending LOTS of money and getting a whole suspension tuned for your Jeep. Most lift kits out there are like "Frankenstein lifts". Buy proper parts from reputable brands and your Jeep will drive like stock or better, regardless if you pick from different manufacturers or buy a whole kit.
When you modify a Jeep you will always risk messing something up. If the work is done incorrectly, or if you got a defective part. It is the risk of modifying a Jeep.
Dadawada
Barrett
Raleigh, NC
Clayton arms
2.5 springs
Reid knuckles
Apex steering boost
35” Toyo at3
Fox DSC 2.5 shocks
Fox ats stabilizer
Sounds like a nice rig. Too bad they couldn't get it to work.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
Clayton arms
2.5 springs
Reid knuckles
Apex steering boost
35” Toyo at3
Fox DSC 2.5 shocks
Fox ats stabilizer
Out of curiosity, you have a track bar tower on the axle side and what does the angle comparison the track bar and drag link look like? Track bar and drag link should be at similar angles. Typically without a track bar tower you end up with one at a steep angle and the other at a shallower angle. This can induce bump steer which can either trigger DW or can feel damn near the same if it's bad enough.
Jjirish
Jenne
2021 Jeep 392, 2024 Jeep 392, 2023 BMW X7C
Lurking the forum
cosmokenney
Cosmo
Loyalton, CA
2019 JLR (2-door)
All of that money and you haven't tried the least expensive thing you can do in a modded Jeep: Slow down.
