Off Road Lights
xpsruler
2018 JL Wrangler Sport
Anyone install any aftermarket lights yet? There's some good mounts out now and am curious to see how people are routing wires who don't have the auxilliary buttons.
xpsruler
xpsruler
So I took a look and think I've found where to wire through the firewall. Under the hood on the driver's side there is a plastic cap.
Here's the view of the cap from the driver's side footwell. I haven't tried taking it off as I'm not quite sure how it works. Any ideas?
I also found a wire with an open connector in the footwell area as well. Any idea what this would be for?
Artec
Rock Sponsor (Level 1)
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
We have installed some Rigid Industries Midnight Series lights on Our JL here at Artec Industries We currently have the Hood mount for a 50" bar and Dual Cube A pillar brackets available and ready to ship . We are currently designing a Single cube pillar , and a over the windshield light bar mount
we also have 10% off for forum members coupon code jlforum
ArmyCrawler
NJ
Black JL Rubi
Any that work with the windshield down?
Artec
ArmyCrawler
NJ
Black JL Rubi
No these will not allow the windshield to be folded
Thanks for your quick response! Given your experience with making these, do you think it is possible to have cowl lights that do not interfere with the folding of the windshield?
Artec
You're welcome. The only way you could have pod mounts not interfere with the ability to fold down the windshield would be to have them mounted on the side of the jeep so they clear the windshield as it folds down so they would stick out past the sides of the jeep
ArmyCrawler
NJ
Black JL Rubi
Makes sense. Is that effectively making a bracket that goes in the opposite direction, but with the same mounting points? (I know I am simplifying what that takes, just curious) It could probably stay within the profile of the mirror, so the vehicle wouldn't be any wider, if I am looking at it correctly. Thanks!
rizej
Jared
Denver, CO
Definitely awaiting the over windshield mounts so that way functionality of the windshield remains. Those brackets look really good so hoping for another nice setup for the over windshield mounts.
Justin1239
Justin
Ponoka AB
2018 JLU Wrangler Rubicon
Will you be able to use the over the windshield mount with the dual cube mount?
xpsruler
xpsruler
I would like to know thi as well!
ashg2000
Ash
Atlanta, GA
Jeep Wrangler Rubicon JLU
Hi, I am planning to install LED bar and cube lights this weekend on my automatic Rubicon JL. Were you able to figure out how to pass the wires through the firewall from the driver side? I have read there is a plug under the hood and then also on automatic JL there is a way to pass through a plug on the extreme left of footwell (where clutch is in manual). Not sure what is the best option to run the wires.
xpsruler
xpsruler
Yeah. That plastic cap has tabs on the interior that can be squeezed which will let it pop out on the engine side.
I popped out the cap and used a rotary tool to make a hole in the cap... This lead to hearing a lot of engine noise however so I then put a rubber strip across the hole of the cap which sealed the wires :).
I since have installed the S Tech switch kit which is definitely a more factory looking option.
vic
Vic
CA
2019 Punk'n JLUR; 2013 Orange JK
Does the Artec hood mount whistle at speed with the 50" bar?
rs680
Rick
Barrie Ontario Canada
2018 JLU Rubicon
I got these light bracket off amazon they were easy to install. I added the overland Bound emblem and mounted Rigid Cube lights.
