JeepAustinWeird
- Steve
- Feb 20, 2020
- Austin, Texas
- 2018 JLU Rubicon
What I am curious is can one location serve to be the grounding spot of more than one light. I originally picked two different spots when I installed the two light bars (about 6 months ago) to have 2 separate grounding locations, but when I installed 2 Rigid DSS Cubes by my A Pillar, I used one of the already used grounding sites to serve to ground this also, so that particular spot has 2 separate grounding terminals/connectors (one from a light bar and one from the 2 Rigid Cubes). I did separate with a nut just so they wouldn't physically touch (which I'm sure wasn't needed, but none the less). I am guessing it's okay to do this meaning not having to use 3 separate locations to ground the 3 lights. I just had to replace both my batteries about 3-4 weeks after installing the Rigid lights and putting the second ground at same spot as the one light bar and am hoping the timing is just pure coincidence and that I didn't do something as the cause that is draining my battery. I am going to try and attach picture to show what I am referring to.
