OEM Shock Leak
Brownpow121
Aaron
2021 JLU Altitude Sport V6
Hi all. My 21 JLU has a leaky passenger front right shock leaking. 21k miles, driven like a princess, and 3 months out of warranty. Little pi$$ed that a shock would go bad at this short mileage point. Ran it in for an oil change and the dealer tech pointed it out.
Any thoughts on the manufacturer of the shock? Happy to pay for labor to a fix but that is a really sad product and want to reach out.
jludave
The Isle of Long
IT Manager
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
Occasionally, on here I have seen some leak at lower miles. Jeep mfg thousands and thousands of shocks, so it does happen sometimes. Not an excuse,but.
You can buy used shocks on this forum dirt cheap and replace it yourself in about 10 min.
jadmt
jeff
montana
I would not be upset...I would look at it as an opportunity to get a nice new set of shocks by Falcon, Bilstein, Fox or any number of aftermarket shocks. shocks on JL's are super easy to install.
Brownpow121
Brownpow121
Aaron
Just stunning that in 2024 they wouldn’t be built better on these. I’ve had many cars go 150k+
That said, I’ve done plenty of work but haven’t done shocks. Recommend a good vid out there? I don’t have any air tools or a lift
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
my 3 years was up in February.
I have a full set, front & rear, factory Sport shocks like new. Message me if you're interested. They are very easy to change out, you don't need a lift or air tools.
Kracka
Christopher
Oak Point, TX
C8 Corvette, 19 KL Trailhawk Elite, 23 JL Rubicon
All 4 of our '23 JLUR shocks were replaced under warranty @ 20k miles due to excessive leaking. I took the warranty replacements off 100 miles later and sold them while still fresh (I installed a Bilstein lift). Luckily, good shocks are cheap on this platform!
With all that said, you may have some luck with a goodwill warranty repair due to your low mileage and the fact you're barely outside the 36-month window. Be nice & polite with your service advisor... I had a $1,200 repair covered on our 2019 Cherokee Trailhawk this way.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
How’s the ride on the Bilstein lift?
Kracka
Christopher
Oak Point, TX
AlgUSF
Melbourne, FL
2021 JLUS, 2014 Tundra, 2013 Odyssey, 2002 Civic
They're super easy bolt on top and bolt and nut on bottom. I believe they are 18mm/each.
Edit: you do have to pull the fender liner back a bit to get to the top bolt, like others have said they're very easy to do on the Wrangler, much easier than any of my Hondas.
Kracka
Christopher
Oak Point, TX
Absolutely love it! Better than stock; rides really nice. Zero complaints from my wife either and her commute is 75-miles roundtrip.
They offer SD & HD spring (HD w/winch) kits.
https://bilstein.com/en-us/bilstein-jeep-wrangler-jl-lift-kit-boosts-performance-for-rubicon-models/
My wife earned 7 Jeep BOH trails badges on the stock Rubi suspension; tomorrow will be the first excursion off-road with the Bilstein setup (Bistein lift + Bilstein steering damper + Mopar LCAs).
whitechocolate
Fl
2021 JL 80th Edition
So did my 21JL, OEM monotube "Heavy Duty Suspension with gas Shocks"- same shock, same mileage 21k it's being repaired under CPO warranty.
Kracka
Christopher
Oak Point, TX
Seems like ~20k is the magic mark for these things... I believe they're made by Tenneco, which is the parent company of Monroe.
Zandcwhite
Zach
Patterson, ca
2019 jlur
Stock shocks are garbage anyway, the sports have less than a 6" stroke up front. So yourself a favor and upgrade. Even rubicon take offs are a big improvement but I ditch those almost immediately too. You can fit a shock with almost double the travel at stock height, why run cheap, underdampened, short stroke junk period? Or out of warranty especially? Why people want to replace the factory junk with more factory junk? The stock f150 shocks on the work truck are just as bad. The 15 miles of dirt and washboards out to our property was brutal yesterday and had me missing the fox 2.5s on my mojave in the worst way. Felt like it was going to shake apart and the shocks seemed to stop dampening at all half way in. $40k+ rigs with $30 shocks, makes sense....
