OEM LED headlights
JLEEPER
JEFF
NEW YORK
www.headlighthaven.com
2019 SAHARA, 2003 EVOLUTION, KX125
lighting specialist
for anyone without the factory LED headlights, there are other options. We just installed set of our aftermarket LED headlights. They require our adapter rings, but they line up great. They are a little smaller in diameter to the OEM version, but our adapter rings feature a nice rubber ring to fill in some of the gap. These DOT approved headlights have excellent beam pattern and no flickering, all plug and play to factory connector using our adapter. The halo will turn on as soon the lights are turned on, or using the included 'trigger wire', the halo can be wired separately to parking lights(or anywhere)
Jeep Wrangler JL OEM LED headlights IMG_3438
Jeep Wrangler JL OEM LED headlights IMG_3433
Jeep Wrangler JL OEM LED headlights IMG_3436
nag22
Nick
New Jersey
2018 JLU Wrangler Sport, 2012 JKUR Gecko Wrangler
Is the middle part projector for low beam and then it uses the reflector part for high beam?
Can you throw HID bulbs into this without blinding oncoming traffic from the "no cutoff" problem?
I honestly have no idea
steffen707
Wisconsin
2020 Gladiator Sport S (Gladys) - 89' Civic SI
are the middles of the lights projector and the top and bottom reflector?
JLEEPER
JEFF
NEW YORK
lighting specialist
yes, the middles are LED projectors, very bright with a nice DOT cutoff line. Tops and bottoms are reflectors. 3000lumen low beam, 6000 high beam. Total power 60w
steffen707
Wisconsin
Are there separate led bulbs for the high and low beam, or is it a single bulb?
JLEEPER
JEFF
NEW YORK
lighting specialist
these are all sealed units. Have a 2yr warranty if any defects we would just replace the light
weeitsmikelee
New Jersey
‘21 Wrangler 392; ‘22 Grand Wagoneer; '15 Harley Sportster; '82 Honda Silverwing
Healthcare
These are kinda cool. How much for just headlight(s)? In case I order for the bike
Mickgolf00
Perry GA
Jeep Wrangler JL
*UPDATE*. Ran into a little delay. The original idea of using the first fuse adapter was a bust. It's too big to go into the JL fuse box spare slots. I found a company that pre wires fuses. Gonna HAVE to go with that one. Other than that. Everything is ready to go. Just gonna wait on that to come in the mail. I'll keep you folks posted...
Just curious. When you're wiring these in, do you run both lights into (1) fuse (ie..cigarette lighter) or will you run to two separate fuses? I may have missed that in this thread but wanted to confirm with someone that's done it. Finished pictures would be nice if you/anyone has them. Appreciate it!
dcdanny
dcdanny
Daniel
CA
2014 wrangler sport. 2018 Rubicon
So you just took an oem LED housing, and put beamtech LED bulbs into them off of Amazon? Do you have that "the snow won't melt" problem?
Nope. They're OEM. Take offs from another JL
dcdanny
dcdanny
Daniel
CA
Both into 1. So ultimately you'll be splicing 3 wires together. One from each light & the fuse wire. Which is (pic posted). Then into the cigarette fuse slot
Jeep Wrangler JL OEM LED headlights Screenshot_20190208-160735_Chrom
Mickgolf00
Perry GA
Jeep Wrangler JL
Jeep Wrangler JL OEM LED headlights B455FA31-20E5-4937-80ED-381B5A5BAE30
Jeep Wrangler JL OEM LED headlights 3F10B843-6593-4AF7-9F20-39EA860A59EA
Another successful upgrade thanks to the folks contributing to this thread. I want to especially thank @EgGreg. I ordered his harness and wired it up. Flashed my Jeep with the JL TazerMini. Everything worked as advertised.
dcdanny
dcdanny
Daniel
CA
Badass!!!!!
