OBD J-Scan
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Anyone ever use this version of J-Scan. The OBD module is on Amazon for 140 bucks, then the app for one vin is 25 for the year. Just wondering if this is even woth it. Thanks
THAW
Foster
23 JL4DrRubicon
If the $140 OBD adapter you're referring to is the OBDLink MX+, I have it and it works great. I paid $60 (double discount sale) for it about half a dozen years ago, though. It looks like there are less expensive, JScan-approved options.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Dale's Jeep
Dale's Jeep
Dale
Michigan
Thanks everyone. What can be done with this device I.E. brake bleeding plus abs module?
Terrymo
Terry
2023 JLURXR 3.6 ET
You can get the app for free if I remember correctly. That way you can see what all is there. I think you pay when you buy a license for your specific VIN.
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Just use one of the recommended ones that JSCAN suggests, I tried the high $$ one and also one of the cheaper versions and they both worked the same, been using JSCAN since like 2019 and it has some great features, the Start/Stop function is subpar so I use a Start/Stop Elimantor for that and all have worked perfectly.
WontonJLUR
Suffolk, VA
2019 JLU Rubicon
To answer this question specifically, yes you can do an ABS bleed with OBD J-Scan.
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
Speaking of J-Scan. Anyone know how to navigate it to the point where i can do a transmission relearn? Just regeared and want to reset that if possible.
WranglerMan
Will
Greenfield Indiana
I believe it’s under the Adaptation>Vehicle Maintenance. There is a long and short quick learn option.
Not 100% sure but I think the JL will relearn on its own but don’t take my word on it, you may be better off going into axle ratio and changing what ratio gear you went to it’s under Tire and Axle settings
Rogersocal
Roger
Yes, I have been meaning to do that. Gotta unmarry the Tazer and its a proccess.../sigh.
58Willys
Geoff
Western Washington
2018 JL Sport
Go to “Adaptations” / Tire and Wheel Settings”. You also have to run 6th gear relearn proceedure.
jeepin2025
Lew
United Kingdom
2018 2.2l Sahara JL
Does anyone know if you can monitor regeneration cycles for the DPF with J Scan, and soot levels etc - 2.2l Multijet
