New Steering box install
roaniecowpony
Retired Engineer
I’m still running the aluminum box in my 2018 JLUR. It seems to be steering fine, but I don’t have anything to compare it to. I’d like to get it changed before I run out of warranty. I’m at about 35K now. Do I have to prove some malfunction to the dealer to get it done? Or, can I just claim that the steering wanders a bit, and assume they’ll just change it on my request? Any thoughts?
John,
All I had to do was to show them the TSB and ask if they'd do it.
I bought a 2018 new and found it had rediculously loose steering. So much so that I had it in an alignment shop after driving it an hour. It is the reason I joined this forum. Upon reading the issue was being experienced by most new owners and that they were getting the "that's normal" from the dealers, I elected to spend my money solving it.
I installed a bunch of aftermarket steering parts: tierod, draglink and a trackbar. The trackbar took out 3/4ths of the loose feel. I adjusted the aluminum (V 1.0) steering box down to have very little play. The steering was very good. I wanted to get the new steering box for a long time and finally took it in before the warranty expired. After they put it in, I was less than impressed. It's ok. But it's not better than the aluminum (V 1.0) that I had adjusted. Maybe not quite as tight.
Your 2018 will have a earlier part number trackbar (if it hasn't been replaced) that gets replaced during the TSB. That part alone is worth getting the TSB done.
InjectedCJ7
Michigan
2018 JLUR, 1978 CJ-7
John,
roaniecowpony,
From one retired engineer to another, thank you for the helpful info! I doubt my track bar has been replaced, as I bought it with about 27K on the clock. Do you happen to know what the earlier part number is, so I can check it? Actually, my steering doesn’t feel too loose, right now, but there seems to be a bit of overall looseness when hitting bumps. I have two other solid front axle vehicles, a 1978 CJ7 and a 2015 F250, and the new JL seems worse than both. I’ve even had a few episodes of death wobble, when hitting large bumps while going through a corner. I haven’t driven any other JLs, so I’m not sure if mine is normal or not. Also, do you know the TSB number?
Thanks,
roaniecowpony
Retired Engineer
