New Raptor Load Range C 37s?
Mattyp1214
Black 2018 JLUR
I’m really excited to see these mounted. Since I know they are closer to a 35 inch I think it will actually be perfect. I just wanna see what they actually look like compared to the 33’s that come with a Rubicon.
Its quite a difference from stock. They are about 1" bigger than my 35 ridge grapplers (if they are the same diameter at the D rated)... I think it's going to be the perfect size.
Here's pictures of D-rated 37"
https://www.jlwranglerforums.com/forum/threads/pics-of-37-ko2-tires.8960/
OffroadCalling77
Josiah
Brea, CA
21 Rubicon 392, 21 Sahara Altitude
Biz Owner
What do you think with the 392 semi lifted? Will wheel spacers need to be added or do you think these can work right out of the box since they’re smaller than a standard 37?
Mattyp1214
Black 2018 JLUR
They will probably work fine on the road. But off-road it may rub without more modifications. Wish The 392 was out when I bought my Jeep, I guess I’d be much more broke tho!
OffroadCalling77
Josiah
Brea, CA
Biz Owner
I’m very blessed and fortunate to be buying a jeep right now. I’m very excited to get my 392. What additional modifications do you think need to be made? All the normal stuff for 37’s?
jlang
JDawg
2019 Jeep JL Punk'D Rubicon
Semi-Retired
Discount tire just called. My C rated 37’s and wheels are in. Unfortunately, my lift is 2 weeks out…sigh
Mattyp1214
Black 2018 JLUR
Check out YouTube I saw someone running a 392 with 37s. I assume it’ll be similar to a rubicon and you’d want 2”. Honestly I don’t know much about the 392 suspension. I haven’t researched it much otherwise I’d be trying to convince myself it’s a good idea to buy one haha. I’d think it’s going to be comparable to a rubicon model in the amount needed beyond stock.
here’s a link with a forum and a guy running 37s, he says it rubs a littleon stock wheel, maybe backspacing can fix that.
https://www.jeep392.com/threads/392-lift-kits.87/
OffroadCalling77
Josiah
Brea, CA
Biz Owner
Just read through the thread you posted. He is running the 37 Ridge Grapplers, which I know are pretty close to size with a tiny bit of rubbing. I am wondering since these KO2's come in over an inch shorter than the Ridge Grapplers, if they would work with no rubbing? Hmmm
Mattyp1214
Black 2018 JLUR
He’s on this forum too. If you’re driving around town go for it. If down the line you start off-roading then slap a lift on it
OffroadCalling77
Josiah
Brea, CA
Biz Owner
I already go off roading with our current regular so lift it is!
Mattyp1214
Black 2018 JLUR
Fedex tracking says 65# per package, so hopefully they come in at 64# per as far as weight! Mine are getting installed Tuesday. I'll post up a report of how they drive Tuesday night as well
Jeep Wrangler JL New Raptor Load Range C 37s? Screen Shot 2021-06-16 at 10.29.32 AM
Mattyp1214
Black 2018 JLUR
I'm shedding about 11# from my 35" ridge grapplers, thats crazy. Obviously much less aggressive thread and sacrificing sidewalls no doubt, but that helps offset the weight of a bigger wheel
RubiRed
Richie
WA
JLR, Odyssey, S2000, 911
My first two tires arrived Monday and my remaining two tires arrived today. Brought a bathroom scale to weigh two of them. 65.4 lbs and 64.2 lbs. So the average is right around the advertised 64.8 lbs BFGoodrich claims. I'm happy with that :like:
Jeep Wrangler JL New Raptor Load Range C 37s? 97C9FFFF-480C-4935-AC88-F56466298D54
TJP
PA USA
20 JLU Rubicon
Nice. So the D load rated are 71lbs for a drop of 6lbs per tire moving to the C rated?
Checking my stats and math :p
jerseymike
Allentown, NJ
2018 Wrangler JL Unlimited Sport S
D rated bfgs spec at 69lbs
very light for a 37 so these are about 5lbs lighter
