New JL owner-possible help
mph27pjm
Patrick
Myrtle Beach
2024 Wrangler High Altitude
Hello Everyone, I am a previous 2009 JK owner and just purchased a USED 2024 High Altitude with the 2.0 engine with 22k miles and without 4XE. I have been looking for more information on my purchase as there is no information on the Carfax and unable to find the original sticker. I've been reading up and all articles claim the High Altitude was only an option for the 4xE, not gas. I have been able to access the build sheet which confirms my limited infomation, but am very confused in what I really have. Would anyone be able to point me in a direction to find original sticker and/or more info. Thank you
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Can you use the vin to search it on Jeep site?
mph27pjm
Patrick
Myrtle Beach
Plug your VIN into the link below and select "Jeep". It will pull your window sticker straight from the manufacturer.
https://windowstickerlookup.com/
Thank you but this is where it gets fun… can not find original sticker, everything says window sticker in unavailable for this VIN
Jeep Wrangler JL New JL owner-possible help IMG_8892
NWJeepr
Twin Peaks
2025 Wrangler 2-door
Is it possible you're reading it incorrectly (mistaking 0 for O or 1 for I, etc?) If you'd like to post it here I'm sure someone can help you try to find it..
mph27pjm
Patrick
Myrtle Beach
Thank you, VIN is correct, I have downloaded build sheet but sticker, nada….
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
The build sheet has significantly more details than the window sticker for most things. It should say what country it was built for. A different county (e.g. Canada) could explain why you can't pull the sticker.
mph27pjm
Patrick
Myrtle Beach
Thank you, I thought the same thing but build sheet shows Toledo, Ohio.
garykk
Gary
Southern NM
2022 JLURD
As far as I know they’re all built in Toledo. That’s not necessarily where they are headed.
Kashmir8
2022 JLURE Granite, 2023 Volvo S60 Recharge
I'm confused. What exactly are you trying to figure out? Whether you have a High Altitude or not? Or if you have a 4xE or ICE?
mph27pjm
Patrick
Myrtle Beach
Thank you for the question. I have no doubt that I have a High Altitude ICE, I’m trying to find out any history on this 17 month old vehicle. Car fax shows put into service on July 13, 2023 and next item is for sale as a CPO in South Carolina, no addition items listed. When I attempt to find original sticker, all is shows is sticker is unavailable.
every article I have read claims that in 2024 they ONLY produced High Altitude in 4xE version, yet I have a ICE. If I was ever to sell car (love it btw) the sure the new owner will have questions I can’t answer.
just hoping to find out more then I have already.
thank you.
gek
Code Monkey
Looks like you might have yourself a Unicorn. I see no references to an '24 HA that isn't an ICE.
Here are the two links I always use, just put your vin at the end and hopefully it works.
https://www.jeep.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
https://www.chrysler.com/hostd/windowsticker/getWindowStickerPdf.do?vin=
I would type the vin in as they might not work if you happen to copy and paste as sometimes special characters can sneak in there depending on where you are copying from.
