New brake design? Cannot replace just pads?
mgrowc1
United States
Wrangler
Good afternoon,
My 2018 JLUR needs new pads on the front. Just got a call from the dealership where they confirmed it is just the pads worn out and only the front. However, they are telling me that Jeep has come out with a new design so they will have to replace the pads and the rotors and want nearly $900 to do it (just the front).
Seems absolutely crazy right. So my question is if this is a real thing and I am essentially going to have to replace rotors as well because of this design change or if they are BSā€˜ing me. If the latter, would going to somewhere else that is not the dealership void any kind of warranty as that is why I use the dealership (have the extended MVP warranty).
Thanks in advance.
Fitzz47
Delaware
2018 unlimited Sahara jl
This is the pads my dealer told needed replaced. I replaced my pads myself. And did not change rotors. I have a 18 Sahara. Don’t ever trust your dealer.Sahara and Rubicon have the same Heavy Duty pads. As you can see I didn’t need pads.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
If you dumped a pad lining and are grinding, I'd at least turn the rotors. Same if you've got pad deposits and are pulsing.
Aftermarket rotors are so cheap, most don't even screw with turning/resurfacing them any more.
Midwestjeepguy
Midwest
2018 Jeep Wrangler JLUR
I have an 18 and you can absolutely change just the brake pads. I've replaced brake components on it myself. Either their explanation was awful in that you 'should' replace the rotors too due to warping/another issue or they have no clue what they are doing. Either way I'd go elsewhere.
mgrowc1
United States
Wrangler
Sounds sus as the young folk now say. Can you do them yourself or have a buddy help you?
Was worried about warranty to be honest. Also dont like messing around with brakes.
Other dealership is going to do them anyway and not change discs.
mgrowc1
United States
Wrangler
Saying that though if I got someone else to do it not at a dealership is there any warranty implication?
mgrowc1
United States
Wrangler
I thought so too. I even called back and asked them to confirm. They did. My rotors are fine but the new design means everything needs to be changed. Considering doing it myself now.
azjl#3
North AZ
I just looked at rock auto, I'll be damned, they only sell rotor pads and disks as kits, thats what mopar does I bet, and all the brake parts are companies I have never heard of, from $98 an axle to $500 for all four. At Autozone, You can get just pad for 35 up to $90 per axle for duralast gold ceramic, those have worked well for me.
AZ Hella
Sonoran Desert
JLUR
Jeep updated the front brake setup and you must purchase new rotors that are compatible with the new pad design. Here is the info
Front Pads
https://parts.allmoparparts.com/oem-parts/mopar-front-disc-brake-pad-kit-68635837aa
Front Rotors X2
https://parts.allmoparparts.com/oem-parts/mopar-brake-rotor-68564973aa
Rear Pads
https://parts.allmoparparts.com/oem-parts/mopar-pad-kit-front-disc-brake-68386838ad
Please use code VIP50SHIP for 50% off shipping.
Thank you!
- Benny
This is from All Mopar Parts. They indeed updated the brakes and you need to buy rotors if you are going with Mopar. Aftermarket you can just do the pads.
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
Front Pads
Front Rotors X2
Rear Pads
Thank you!
- Benny
So I have a 21 JLURD. Are you saying that Jeep upgraded the rotors from the ones which were delivered with mine after I purchased it and that I need to replace the rotors and pads if I go with Mopar pads? Just trying to understand what you’re saying.
AZ Hella
Sonoran Desert
JLUR
I don’t think you can buy the Mopar pads anymore. But I’m not 100% sure. Your best bet is to talk with a Mopar parts department.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
I'm on rockauto, I see plenty of brake pads alone.
Jeep Wrangler JL New brake design? Cannot replace just pads? 1696977317181
