Mudflaps and Rubicon Flares?
FUHL
Robert
Sandpoint Idaho
cmott426.wixsite.com
2013 F-150 Ecoboost 2018 2-door Rubicon 2013 Range Rover Evoque
CAD Drafter/Engineer
I too made my own. Roughly a year goes by and still nothing for the Rubicon.
Jeep Wrangler JL Mudflaps and Rubicon Flares? IMG_20190120_180811-800x450
Jeep Wrangler JL Mudflaps and Rubicon Flares? IMG_20190120_180827-800x450
ToolMan514
Tim
Montréal, Québec, Canada
'22 Rubicon 4xe
My custom mud flaps help a lot, but they're not perfect. I could have gone lower, but then I'd likely have to remove them completely for proper off-roading. I would think a proper vendor solution might be closer to the tire and block more spray. I'm still very happy with my install.
Jeep Wrangler JL Mudflaps and Rubicon Flares? IMG_20190131_074638 - Copy
Jeep Wrangler JL Mudflaps and Rubicon Flares? IMG_20190131_074626 - Copy
IndustrialAction
Patrick
Slower Lower Delaware
2019 Wrangler JLUR
So there are no vendors making just flaps for the front of a Rubicon? I put 35s on with a -12 offset and the spray surprised me. Who needs mud when I can just drive through a puddle and drench the entire Jeep? Ugh. I don't really like flaps but I've got to find something. My side steps are no help
55WillysWagon
Jon
1955 Willys Wagon, 2019 Jeep Wrangler OB JLUR
I just ordered them after seeing your post. My JLU has Rubi rockers so hopefully these will work.
Wow, those look great. Looks like they even have cut outs for the sliders up front? I'd like to see some details on the front mounting method.
Edit: Added rokblokz install instructions
DanW
Indiana
@DanW what do you think of these Rokblokz mud flaps?
If those are the ones that are quick detach, I'm very interested in them. $159 is steep, but the fact they are able to be easily removed and reattached might make them worth it. I'm looking closely at them and may pull the trigger in the next couple months.
55WillysWagon
Jon
Jared at Roksblokz is going to confirm if I can purchase just the fronts. The rears require removal of that goofy little inner fender panel at the bottom to attach. I'm mostly interested in keeping crap off the doors, hinges and rear fender extensions. I think the set is $159 because the rear set has multiple pieces and hardware. Fronts are simple.
See response to me below:
We know that the Jeep community is very used to customization, and because of that there will be some unique requests and we will do our best to identify which ones are more common. With that said, you are the second person to ask about front only flaps, so I am working with my team today to get an answer on that for you guys.
The rear adjustable flaps are pretty easy and once setup, are rock solid. We debated about doing a standard set, but based on feedback and performance, right now we feel as though the best value is what we developed. We put a lot of passion behind this one.
Lastly, thank you for the tip about the instructions. I grabbed my engineer and we made the change to explain that that factory plastic liner is no longer needed after that step. It can go in the trash bin or on the shelf. Since you pointed that out, when you go to order your set be sure to put in the order notes that Jared offered a free vinyl sticker. Just pick your color and we will include it.
I will be in touch about the front only option.
Please let me know if you have any other questions.
Thank you,
Jared
DanW
Indiana
Thank you,
Jared
What's the contact info? I'll put a call or email in, too, to let them know there is a good market for fronts only. The cost is the only hangup. If they were around 75 to 100 bucks for fronts only, I'd be buying today.
55WillysWagon
Jon
See the link below. Not sure there is a phone number, email inquiry only. Tell them you found out about them on this site.
https://rokblokz.com/pages/contact-us
DanW
Indiana
55WillysWagon
Jon
Just received this from Jared. Very responsive!
Hi,
I met with our team and we are going to move forward with a front only set, but we are going to need until Tuesday to have that listing up and pricing just right. I checked the comments and it looks like some others are interested as well, so we will be sure to communicate with all of you about this. I am sure that the inbox is filling up.
Are you good until then?
Thank you,
Jared
