MPG surprise!
TimmH
Timm
2018 JL Wrangler Sahara 3.6 Auto
Sitting at 11K miles and about 20mpg as of late, which has definitely been nice. Still having to manually add 3-5gal each fill up since it clicks off around 16-17gal when I fill up.
I can't remember who, but I did see a post on the forums stating if you keep your RPMs generally around 1.5-2K you'll see an improvement
Have you tried pulling the pump nozzle out an inch or 2. I notice early shutoffs if I have the pump all the way in, but much less if not.
I started out in the high 19's low 20's, but after changing wheels, I dropped to the 17's and 18's.
Visible15
Massachusetts
2018 Wrangler JL Sahara
I have tried the nozzle trick at different stations, generally helped for maybe a gal or two? Otherwise same issues, thanks though!
Harleydz
Euless, Texas
2014 Grand Cherokee Summit
Just curious. Who in thos group thimks that the mpg computer is correct? I have a jeep that's not accepted by the JLUR or JLR or any other JL owner.(WK2) With a 3.6. I calculate by dividing miles driven by gallons pu in at click off. My mileage is consistly 2 2 1/2 mpg worse than what the computer says. Which is more accurate? Doing it old school or looking at the mpg on the dash?
TimmH
Timm
Old school is more accurate.
But over the last 7000 miles my computer and my manual calculations have gotten closer, to the point they are within about 0.5-0.7 mpg apart
JMurph
Jerry
Bell Canyon CA
2019 Sahara
When I get gas at Costco. If the pump is on the right side of the car, the long reach makes the nozzle slip out a little and shuts down, often. It’s finicky at other pumps as well. I get just over 20 mpg in my mall crawler.
AlamedaJeep
Jim
Alameda, CA
2018 Jeep Wrangler JL Unlimited Sport S
Mine shows a little higher on the computer. It’s usually 1/2 to 1 mpg higher than hand calculated, but it’s reasonably close.
Budagreg
Buda, Tx
2018 JL Rubicon 2-Door Turbo, 2012 BMW 328i, 1999 Miata, 38' Fleetwood Expedition RV
+10k miles with 21.1 mpg (calculated) vs 23 on the display. Mostly urban commute with stock 2 door Rubicon.
I leave the center screen displaying the MPG graph to encourage better mpg.
I have a cool Ap on my phone that tracks every gallon of Premium I've used.
Worst was rock crawling @ 19 mpg LOVE MY TURBO!
OldJupiter
Old Jupiter
NJ
2 Door JL Sport
25.4 mpg (on display) on my casual Sunday drives. 24.5 on my commute. Driving the 2.0T Sport S stock everything 39 PSI all around.
Calculation average seems to be 21.5 mpg at 418mpg per tank.
shaneR
Shane
Seattle
Jeep Wrangler Sahara JL & an Audi TT
Felt the need to show off my 27.1 average on the dash display. I haven’t figured out how this thing averages. It usually is around 23 but bumped up significantly on a +150 mile drive. Stock 2.0L Sahara.
Jeep Wrangler JL MPG surprise! AF2784D1-A0A1-4394-8BBB-27B0033EDCA8
roaniecowpony
Retired Engineer
I'm probably only getting about 14 mpg average on a stock JLUR. I drive it pretty hard in the city traffic. It still gives me a big smile I'm sure off-road it gets even worse mileage. Maybe half that. But I will use it for what I bought it for.
4x4Funlover
Rich
York, PA
25 RHO
So my Rubi on 37's was only getting 16.8 MPG when I had the tires filled to a supple 28psi, I bumped them up to 32psi and my MPG has jumped up to 19.7 still have a good contact patch after chalking but I do get bounced around a little more on the 6 mile stretch of country road I have going to and from work
okie dokie
OKC
2019 Sahara
To get this type of mileage, you have to drive 55-60mph down the highway. Who has time for that???
Doing 75-80 from OKC to Santa Fe and back. I will say on the way back the wind was blowing and it felt like the hand of God was pushing her down the road :)
Jeep Wrangler JL MPG surprise! 20190421_145837
Billyraff
Bill
Illinois/Michigan
2019 Wrangler Sahara 3.6
Quality Specialist
Took the MOAB on a roadtrip this weekend. 200 miles, mostly highway, 22.4 mpg
Sean L
Sean
North Carolina
One thing to realize about the discrepancy between the manual math and the computer average is that the computer will get to a point where old data is purged. So the computer is only displaying the average for the past X Miles/time period... It seems like it doesn't even last a full gas tank.
