shadowmoto17
- Jonathan
- Jun 25, 2019
- Honolulu, Hi
- 2019 JLU Sport S
- Occupation
- Military
- Vehicle Showcase
- 1
Do you have to have the manifold or is that just for lockers? I plan to do that in the future, but for now just upgrading my air compressor for tires. When I was talking to Northridge4x4 they made it sound like the manifold is optional if you're not planning on using it for lockers.Finally got my ARB twin mounted up over the course of the last couple days. Went with the ARB under seat mount and designed/built myself a manifold out of parts that I sourced mostly from McMaster-Carr. Happy with the way it turned out, though I still need to fab up some brackets for the outlets which will be mounted under each of the front seats.
I repurposed the ARB switch/outlet bracket to instead hold a pressure gauge. I tied the switch illumination into my dome light circuit so it lights up for me when I open the door to use it, but it won't remain lit while I'm driving at night.
It is tied into a pressure regulator on one side of my manifold. The other side of my manifold has a ball valve installed in it. This will allow me to air up/down all four tires at once via double ended hoses that will attach to the outlets on either side of the Jeep.
And since there seems to be a lot of concern about modifying the air vent, here's a picture of what's going on under there. The directions tell you to cut off 200mm (just shy of 8 inches), but that's not absolutely necessary (depends on your manifold configuration) and will leave your vent pretty much even with the rear of the body tub crossmember that it's mounted to. I also chose to graft the diffuser nozzle back onto the end of my vent to help spread out the air flow. Overall I think I'm at about 125mm (5inches) shorter than the stock vent configuration.
