Mopar Tow Harness Install
Specter491
'18 Wranlger JL Sport S
I don’t think so, it’s an all in one install, and you’d have to figure out what powers just the 4 pin.
Got it, thanks. I thought you could just wire something to the tail lights. Looks like I'll have to wait for third party options.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
You can try this:
This shows you how to install a JK harness on a JL.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
Finally got the actual Mopar OEM JL hitch installed. Straight forward as many others have mentioned.
cabnfvr
Tim
Hendersonville, NC
2018 JLUL Sport
Retired but working with benefits.
Just reading stuff and came across this thread. For anyone still needing a harness and only a 4 pin I used e-trailer's harness. Much much simpler to install than the Mopar kit. :)
p.s. Thanks to the OP for excellent info on the Mopar install.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
So a bit of an update. My install need for the hitch and harness was cancelled, so I haven’t had a chance to make sure everything was functioning until today.
Before I went to pick up my new trailer, I figured I get out my test light and check the 7 pin connector to make sure all was working. While I had power to the 12v pin, I wasn’t getting power on any of the turn signals, running lights, etc.
I pulled part the left tail light and the yellow wire that was added during the install was getting power. I pulled apart the right tail light and checked the wires into the module that is added during the install and noticed that the main power line was not seated properly. Pulled it all apart and got it out back together. Tested again and all was working!
Picked up my trailer and the lights worked perfectly! A relief.
se7en
Knoxville, TN
2024 Rubicon X / Zynith / 3.6 Auto / SOT / XR
@mergedown - I finally had mine installed by the dealer. But just as an FYI, they flashed the ECU as part of the install. When I asked why, because I had not read where that was required, they said that the ECU will not know that the system is now equipped with the trailering package and that it was part of the required installation. Also, they said that now it’s part of the overall build sheet. As in, if I were to get a new printout of the window sticker, it would be printed on it...not as factory installed, but a dealer installed option and would carry the same warranty as the rest of the vehicle. The system reflash is actually printed on my worksheet/ticket from them. Just thought I’d let ya know, in case you wanted to look into it.
mergedown
Jason
Columbus, OH
2018 JLU Sahara
@mergedown - I finally had mine installed by the dealer. But just as an FYI, they flashed the ECU as part of the install. When I asked why, because I had not read where that was required, they said that the ECU will not know that the system is now equipped with the trailering package and that is was part of the required installation. Also, they said that now it’s part of the overall build sheet. As in, if I were to get a new printout of the window sticker, it would be printed on it...not as factory installed, but a dealer installed option and would carry the same warranty as the rest of the vehicle. The system reflash is actually printed on my worksheet/ticket from them. Just thought I’d let ya know, in case you wanted to look into it.
Thanks! I’m aware of the flash. It activates the anti-sway feature, which can also be done with the Tazer.
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
CURT®T-Connector(1 review)# mpn1067436Jeep Wrangler JL Rubicon / Sport / Unlimited Sahara / Unlimited Sport 2018, T-Connector by CURT®. For Models without Tow Plug, 2-wire System, Location: S1. This provides all you need to connect a trailer to the tow vehicle. Generous...Plugs into vehicle tail light assembly to provide a 4-way flat socketSimple plug-and-play design eliminates the need for cutting or splic more details on - https://www.carid.com/2018-jeep-wrangler-hitch-wiring/?filter=1&sub-model[BodyNumDoors][]=4+Doors
OSCAR
Fred
Johnstown Pa
2018 JLU sport, 2018 Grand Cherokee
Has anyone used this? Looks to be the same type connection as the one for the UK used to be. If so it' exactly what I've been waiting for
jeremylj1972
Jeremy
Boise, ID
2018 Wrangler Unlimited JL
First of all...thank you for the write up and photos! I am using this as well as the factory instructions but am stuck. I cannot for the life of me get the front to back red power wire into the harness. I can get it started but it doesn't seem to go in far enough to get locked in with the yellow clip on the harness.
Anyone run into this problem and what did you do to overcome it?
mergedown
Jason
Columbus, OH
2018 JLU Sahara
I know we talked via PM, but I wanted to make sure others saw my response.
I too had a bit of a hard time, but here’s what I did. First, I made sure the yellow clip was fully retracted. I then pushed in the wire as far as I could, and then used a small screwdriver to work it down the rest of the way. It goes in further than you think, but you’ll know when it’s in when you can slide the yellow clip back and it holds the wire in place.
Because I was initially trying to force in the wire with the yellow clip in place, I did slightly bend the connector, so I carefully straightened it back out and then had no issues.
User Banned
Jay
Collegeville, PA
2021 Gladiator Sport S Max Tow
Guitars & Drums
Jeep Wrangler JL Mopar Tow Harness Install 2A913148-A267-48E0-9E63-DA41FBE2E057
Haha. That’s exactly where i got stuck today! Thanks Mergedown for the help via PM as well.
Jeremy, did you get it yet? This is what you’re talking about right? I guess the small screw driver will be the trick!
User Banned
Jay
Collegeville, PA
Guitars & Drums
...and i concur. The hardest part was the fishing of the wire through the firewall grommet. And of course this red wire insertion is proving to be a jerk step. The instructions are only slightly more intuitive than IKEA instructions.
