MOPAR OEM headlight confusion
DocJon
Jonathan
NJ
2022 JL Sahara
Hi Jonathan,
Found your question and want to direct you to this write I did last year in case you haven’t seen it yet. Don’t know if it will answer definitively but hopefully help: https://www.jlwranglerforums.com/fo...oem-led-headlights-swap-what-i-learned.78546/
Best wishes, JBC
Hey JBC
Not only have I seen your post but I saved it because of all the great information! I figured I might need to share those codes with my dealer in case they weren't as familiar as they probably should be.
It was a great write-up!
All the best,
Jon
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Hi Benny
Sure, if I'm not going to need it, I might as well return it..
The cartons arrived yesterday but I won't be able to get to them for a few days. Any special instructions regarding the return?
Thanks much.
Jon
No rush Jon, Send me your order # and I will send you a label.
Thanks,
Benny
DocJon
Jonathan
NJ
2022 JL Sahara
Hey Jon,
I'm thinking that we are going to start offering a separate 2021+ kit without the harness. If you would like to return the unused harness let me know, Its roughly 65 dollars in value.
- Benny
Hey Benny
Finally getting back to you.
The order # 145049288.
If it can still be returned please give me any necessary details.
Thanks,
Jon
DocJon
Jonathan
NJ
2022 JL Sahara
Hey Benny
Thanks,
Jon
Benny
Hate to bother you again, but the PM you sent is MIA from where i saved it.
Would you mind sending another?
Thanks,
Jon
usmc93
Huntsville AL
2022 Wrangler Unlimited
New PM sent.
Thanks!
I realize this post is a bit older, but I am hoping to clear up a bit of confusion on my end:
I have a 2022 Wrangler Rubicon that did not come with the LED package. I ordered some LEDs direct from Mopar (I couldn’t find a set to order so I ordered LH and RH individually but they didnt come with any additional wiring). Anyway, If I am reading HH’s reponses correctly I can just plug in the two Mopar OEM LED headlights and once I flash it everything should work correctly? I installed them last night but still waiting to get a Tazer or go to my local dealer. The low beams seem to work fine and the high beams look a little weird and the HALOs dont work at all. Will that all work once I get it “flashed” or do I need additional wiring?
AllMoparParts.com
Benny
NY
2018 JL
Base on the official Mopar Kit data you are also going to need part # 68347117AB jumper wiring. This harness is on backorder with no solid ETA at this time.
-Benny
hoag4147
Colleyville, TX
2022 JLUR XR
-Benny
Shouldn’t need jumper on 22 since fourth wire is present from factory.
hoag4147
Colleyville, TX
2022 JLUR XR
Switched mine over, no additional wiring required. Had Tazer mini and everything worked great. I also swapped in flare DRL’s and LED tails at same time.
Jeep Wrangler JL MOPAR OEM headlight confusion 01C3ECD2-6A99-4AF3-8FE6-847AA2E385EF
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
You should be good to go. What you’re describing; normal low beams but not so normal high beams, no halos - is exactly what I encountered before the flash. Flash should fix everything.
