Mopar Coolant Color Change?
roaniecowpony
Retired Engineer
LOL, I missed it when I poured it in. 90032 is purple out of the jug..
Anyone have the Mopar 90032 orange-pink coolant turn purple?
I've been in the days long process of flushing my coolant system.
Before I put any flush in, I drained the contaminated (oil from oil cooler seals) coolant into a catch pan and bottled for haz waste disposal. To get the residue out, I had a garden hose running in the coolant tank, the plug out of the block and the engine idling for 5-10 minutes, heater on. Then, plugged it, put in the flush and water and drove it for a day. I did this process twice.
Then I drained as above, flushed with garden hose while plug removed, drained completely, filled with distilled water, drove for 20 miles. After completely cooling overnight, I drained again, started it for about 20 seconds to pump out a bit more, plugged it, and dumped in a gallon of Mopar orangie-pinkish coolant. Soon afterward the coolant turned a purple color.
TrailScooter
'20 Jeep JTR, 91 F1504x4 and so on...
Uh oh! You didn't look at it or touch it did you? ?
The spectrumiscopic range reflector disspunged from the minerizer unit. Your Jeep is totaled, dude.?
roaniecowpony
roaniecowpony
Retired Engineer
Do you think I disturbed the capacitive reluctance, causing a shift in amulites?
autotragic
the cornbelt
'21 JLR 6MT
You know I was thinking about flushing my turbo enclabulator just the other day but then I realized man those are really expensive so I better take it to the dealer and let them handle it.
gsbrockman
Greg
Sand Gap, KY
2023 Dodge Challenger Scat Pack Plus A8 & F8 Green
Owner / Operator Brockman Hauling, LLC
Should have used a 2.5 gallon MoPar DEF jug (well rinsed) for mixing of the MoPar concentrate and distilled water, @roaniecowpony
Jeep Wrangler JL Mopar Coolant Color Change? img_7647-jpe
roaniecowpony
roaniecowpony
Retired Engineer
