Maximus 3 Tow Loops
Alan_Hepburn
Alan
Lewisburg, TN USA
2020 JT Sport S, 2022 JLU Sport S
Those of you who have installed the Maximus-3 Tow Loops: their web site says that the bumper and skid plate need to be cut. How difficult was it to cut those items, and what did you use for the cut?
DaddyEngineer
Tomball Texas
2019 JLU Rubicon
While I have the JK Hardrock bumper on my JLUR, so the directions didn’t quite match, I used the 1” hole saw and a reciprocating saw to make the cut. It was pretty easy.
Jeep Wrangler JL Maximus 3 Tow Loops image
Cllowe
christopher
Tennessee
2020 2 door jl
It was easy. I even have a aluminum stubby but more. It is worth it in my opinion. They make towing so easy.
Jgeiken
Jesse
Roscoe, IL
2018 JL Rubicon
I was able to make the cuts without removing the bumper. Just take your time and measure carefully. They aren’t hard to install.
Jeep Wrangler JL Maximus 3 Tow Loops 9E8C279F-BDA9-43CC-A0DA-E1579291561F
KDB
WI
2018 2 Door JLR
Please explain steps in doing this without removing the bumper, what tools did you you use and do you have any pics from the install?
slapshot12
Largo, FL
2021 Jeep Wrangler High Altitude
I just installed them on our ‘21 High Altitude. I measured more than 5 times, then used a hole saw for the rounded end of the opening and then used a cut off wheel for the rest. They look so much better than the standard draw bar that goes the front of the truck.
Jgeiken
Jesse
Roscoe, IL
2018 JL Rubicon
I measured and marked, removed the skid plate to make those cuts, and then made the bumper cuts using an angle grinder/cutoff wheel. Just went slow and it turned out fine.
  • Like
Reactions: KDB
