The Great Grape Ape
- Mar 30, 2017
- Canadian Rockies
- 2015 JKU AspenX 5spd , 2015 JK Sport 6spd
That would be OK is the NSG370 were a better transmission, but it's not. Out of the two I'd say the W5A580/NAG1 is more reliable and more robust, which is why it's nice to see a new 6-speed in the JL (was hoping for a 7-speed). The cost of a rebuild is definitrly cheaper on the manual, but that's negated if you have to work on it more often.3) I tend to buy my Jeeps for the long haul, and I think manual transmissions are generally more reliable and longer-lasting than automatics, and cheaper to rebuild when the finally do go kaput.
Heat is an issue, but the auto has had a cooler for years (longer in the Rubi), ut similarly how many times have you smelt clutch on the trail?
I've had both for years, and while the previous 42RLE auto sucked, the 5-speed that replace it is way better. I have even had the two different 5-speed programming (2012 Euro in my previous Rubi, and 2015 NA now), I prefer the shift points of the 2012 because it was more focused on ppwer delivery not fuel economy, and the auto-stick feature is better on the Euro too, bumping to the next gear of first tap whereas the 2013+ goes into manual mode then changes gear on second bump.
Of all the options slated for the Wrangler the 8HP75 Auto is the most attractive due to its much greater torque handling capability than any currently rumoured 6-speed variant, the Tremec 3160 would top out 200 NM / 150 ftlb below the ZF 8-speed.
I'll still get both, because I like rowing my own gears when not in traffic, but the era of their being significantly more reliability in a manual is long gone.
; JKU I drove around while I was visiting down there was a 6 speed, and the one other Jeep I saw in tiny Elizabeth was a 6 speed.
