- Banned
- #706
Slight creep is because clutch is not fully disengaged. You have mentioned applying more of "the magic grease" and i assumed that is to alleviate the creep you are experiencing.As of now I have zero shifting issues. Just the slight creeping when first putting into gear and that annoying noise when i press and release the clutch pedal after the jeep is warmed up. Not sure I want to do anything to it with under two weeks until we head out on our 2-3 week trip.
If you think that clutch is not fully disengaging because of not enough lubrication on guide causing too much friction with TOB, doing what i have suggested will yield positive result and your creep should disappear.
Obviously with caution and mindful of your planned adventures
