ski-line900
- Kevin
- Jun 23, 2023
- Washington State
- Jeep Willy's Sport
Good job, that master is a bit of a pain to change.
Thanks for those pictures. That slave does not look any beefier to me. Just the same plastic but with a metal extender? Am I missing something? Trying to understand how it’s “better” than stock.![]()
Well, drove into work on it. Clutch feels good. Shifts are much better. 1st and R are no issues at all. 5th, Im not sure. Its not what it was, but I need more time on it.
Obviously I need more time on it. I have 40 miles on this setup right now.
I'm pretty sure I could have bled the stock hydraulics and gotten the same results.
The reservior is sectioned, you have to fill past the max line to get fluid to the clutch pickup. Just a FYI
That was the hypothesis but I agree, this looks consistent with ACT's statement that the JK hydraulics are slightly different in ratio, but aren't any beefier than JL.Thanks for those pictures. That slave does not look any beefier to me. Just the same plastic but with a metal extender? Am I missing something? Trying to understand how it’s “better” than stock.
The reason was for better hydraulic advantage/parts meant to see a heavier duty.Thanks for those pictures. That slave does not look any beefier to me. Just the same plastic but with a metal extender? Am I missing something? Trying to understand how it’s “better” than stock.
Actually, besides my large self trying to get under the dash, it was the easiest clutch master I've done. 1/4 turn into the firewall, genius!! LolGood job, that master is a bit of a pain to change.
Oh disappointing BUT the it could be some air still remained in there and gathered in the line. I'll be interested to hear what happens if you do another dry vacuum for a couple of hours.100 miles on the setup. Its shifting great, but hit the reverse/1st lockout this morning. Clutch hydraulics are going to get bled again, but most likely ruled out.
Next step is pulling out the center consul, and checking for any physical obstructions. Performing a shifter cable adjustment in the process.
Im just taking this one step at a time. My slave had blown out previously, i reset it and never bled it, 15,000 miles ago. So I needed to rule out hydraulics. Swapping to JK stuff was more for feel/hydraulic advantage.
Going to borescope top of trans for foreign debris as well. I have a bunch of pics from inside the bell housing, just gotta pull them off the borescope. I didnt see any smoking gun yet. Which is always the poo poo when troubleshooting.
So the saga continues!!! Lol
Funny you say about the master cylinder. So you turned it from the inside? I got mine out from the other side and it was a huge pain. Looks like I biffed this entire situation from all directions. lol
Ah ok the you did what we did. Getting it to rotate that 1/4 turn was kind of a pain and the brake booster and wiring harness in the way.It's not hydraulics. The fact that its the forward throw gears kinda points to just one of the shifter cables/shifting interfaces having issues.
I treated the master like a locknut, from under the hood I placed a screwdriver against one of the shoulders and tapped it to rotate it. Did the same for installation. Theres only 2 real spots you can get a flathead to initiate rotation. A trim tool was used to unhook the master from the pedal, and snap the new one on after I lubed up that pivot.
Getting my hand on the clutch master electrical connector was crappy. That wiring harness is right on it, lol.
While I was under the Jeep, I inspected all the trans/engine mounts and supports. Just in case something loose/broken is causing misalignment. But no dice there.
I figure between all of us we should come up with something, lolAh ok the you did what we did. Getting it to rotate that 1/4 turn was kind of a pain and the brake booster and wiring harness in the way.
Well keep posting your findings once you do cable adjustments. I'm hoping to get my Jeep back next week to continue troubleshooting.
Ok, I just got first lockout stationary, so I pulled the shifter down off center a smidge, but didnt shift to second, and it went right into first. Interesting...
When you say 1st lockout while stationary, does this mean youre unable to engage 1st while stationary, or youre unable to get it out of 1st while stationary?Ok, I just got first lockout stationary, so I pulled the shifter down off center a smidge, but didnt shift to second, and it went right into first. Interesting...
Car is running, stationary, trans in neutral, clutch depressed, trying to shift into first. I get 1st and reverse lockout ( as in "Locked Out" of) preventing engagement, and have gotten stuck in reverse, but not first.When you say 1st lockout while stationary, does this mean youre unable to engage 1st while stationary, or youre unable to get it out of 1st while stationary?
The way i perceive the post, youre in first and having trouble getting the shifter out of gear to proceed to the next gear or neutral position, and by putting light side pressure on the shifter while trying pull it out of gear it eventually releases? is that right?
Also, when your engine is off how is the shifter operation into each gear? Is it buttery smooth or does it still have a resistance or hang up engaging some or all the gears?
