Lug stud length & nut info
cohocarl
Carl
Michigan
'26 Willys JLU, 6-Speed, Soft Top, 41
Don't know if this will be useful to anyone, but thought I'd post some info on the lug stud length.
I recently ordered a set of A/R wheels and I'm not fond of the long, skinny, splined, zinc coated lug nuts that many suppliers are going to.
I wanted to get regular, 6 sided, chrome lug nuts, and a set of locking nuts that would look better than the trailer hitch ball size Mopar set. Wanting them a little shorter than the 2.1" splined nuts, I wanted to double check the length of the lug studs to be sure I don't bottom out the new lug nuts just in case my new wheels were thinner than the stock wheels.
Anyways...Our lug studs are 1.67", or 42.5mm in length (past the brake rotor.)
Jeep Wrangler JL Lug stud length & nut info ln1
Jeep Wrangler JL Lug stud length & nut info ln3
Jeep Wrangler JL Lug stud length & nut info ln2
Jeep Wrangler JL Lug stud length & nut info lnd
WXman
Central Kentucky
I'm using 1.4" long standard hex lug nuts on mine. It's hard to find those for the 14x1.5 studs, but I found some on eBay for around $15 bucks. They fit perfect with my aftermarket wheels and don't stick out too far.
blnewt
New Mexico
Just ask @cosine he knows!
Thanks Carl for that info, looks like I the ones I ordered might just work :) SWEET!
cohocarl
cohocarl
Carl
Michigan
Another point on the skinny splined nuts is the smaller contact area as compared to the regular hex nuts. It might not be a big deal, but I'd think the larger contact area would be a easier on the wheels.
Attached is another pic showing the depth of the threads on a stock Sport S lug nut, and I held one into the seat of a Sport S wheel and measured the total depth from the bottom of the threads in the lug nut to the inside of the wheel where it would mate to the brake rotor. Again...probably nobody will need those measurements, but that's what I came up with if anyone does.
Jeep Wrangler JL Lug stud length & nut info lugdepth
Kenny
Ken
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
GREAT info - I was looking at 1.5” spacers - you saved me some cutting - going to 1.75”
Thanks
Kevin32199
Melbourne
2018 JL Wrangler 2 Door
Most wheels have 0.550" or around 1/2" pockets on the back side of the wheel between the lug holes. YMMV.
