jl_explorer
- Jason
- Jan 28, 2020
- Whittier, CA
- 2020 Rubicon
So, I got everything wired up to my factory switches, but the one piece I can't seem to find information on is tapping into Morimoto side markers, as opposed to factory side markers, in order to run the backlight. I tapped into the red wire, and it worked for a split second until both the side marker and LP6 backlight lost power. Luckily, removing the tap allowed for the side marker to work again.... Am I overthinking it and just need to tap into the black wire? I HATE electrical and this was my first attempt at wiring something up. The factor side marker has a white wire and black wire, and the instructions state to use the factory white wire. I figured since I had one black, and one red, I was should to go to red.
