Jr88fn
Took my 21 2.0 in for an oil change they said my coolant was low and had suspicious sign of coolant intrusion on dipstick. Scheduled service appt. They pressurized the cooling system to 21 psi, inspected for external leaks in the engine bay and found none. Removed spark plugs and inspected cylinders for coolant intrusion found no evidence. Once engine temp cooled and stabilized they reset pressure tester to 21 psi the system did not lose any pressure. Unclear as to why cooling system was low. The muddy appearance to the dipstick is likely due to an underperforming PCV valve. Said PCV valve was sticking due to carbon collection. Vehicle has not overheated. Any idea on why my coolant is low?
