dragoneggs
- Mark
- Dec 14, 2021
- Seabeck, WA
- '22 Snazzberry Pearl JLR
- Build Thread
- Link
I just recently added SteerSmarts components to replace the OEM tie rod and drag link. Also decided to put a Fox ATS steering stabilizer but havenāt tried flat towing with this set up. The reason for the tie rod/drag link upgrade was because of premature worn OEM components causing death wobble.I looked at that exact center setup and it had good reviews but I ended up going with a fox thru shaft steering stabilizer that steer smart recommended when I put there drag link and tie rod on.
Even the my flat towing has been flawless for several thousand miles, I was worried about getting death wobble when towing thus the SteerSmarts.
The Fox ATS is stiffer than my Exact Center but it doesnāt āreturn to centerā. I havenāt flat towed with my new suspension yet and hope I didnāt screw that up fixing something else! I kept my Exact Center in case.
Good luck finding the solution to your wandering. I can vouch for the Exact Center taking care of wandering of my 2dr (stock and not being towed). It did wonders. My guess is the Fox would have been similar. One thing the Exact Center does is give you a bit more ability to back up with your toad without jack knifing.
