Looking for a Good Battery Post Distribution Block
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
Hey folks!
I’m in need of a good battery d-block system. The nut holding the three wires has only a couple threads engaged on the bolt…
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block 7B96572E-718B-4FC3-96C4-42D566351AE0
I’ve seen these (but not sold on them yet, unless someone says they’re great) and I’m not quite sure how they would fit…
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block 1678985999406
How do you all connect multiple wires?
BDinTX
Dallas, Tx
I suspect all of the current needs to go through this post for the battery health sensor to work correctly:
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block 89F349AA-9883-4172-AA79-BF1C1F0374C7
The L bracket I tried is too thick to use:
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block 5D4D01B8-B39F-4109-88A9-288587775F64
Would love to see a good alternative, or to hear from somebody knowledgeable to speak to that battery sensor.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Ground side? There's one on the fender by the battery I use for everything but the winch.
BDinTX
Dallas, Tx
Very good point, maybe that thing doesn't work like I thought. The only thing on mine are the winch ground and I guess chassis gound. The aux battery has been disconnected.
GATORB8
CLT NC
So if it's a shunt sensor, if it's anything like a solar system, you actually want the "load" grounds on the vehicle side of it.
Basically "skips" it going direct to the post.
BDinTX
Dallas, Tx
Load grounds being something like a winch ground connection?
GATORB8
CLT NC
So, basically you skip the sensor, so it'd depend on if you want the Jeep to "see" it's usage.
The winch ground is such a huge short load, it may be better to not have the Jeep mess with it.
Fudster
Elliot
Athens, GA
2019 Sahara
Hey folks!
Hey Jason:
I've got the OEM battery, put into the JL by Stellantis at assembly, and since replaced, sitting in the garage on a trickle charger as shown:
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block IMG_1617[1].JPG
I got the devices you site from this Amazon link https://www.amazon.com/gp/product/B097Y6ZZGB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
When you asked if they will fit I'm not sure if you meant "in the small rectangular cutout where the terminals lie" and/or "will the devices open enough to fit on the terminal plug" ....both answers from the picture a firm yes. As you likely appreciate, the female side of the terminal size they provide is adjustable and capable of snugging on the battery's terminal plug given the screw that adjusts each female, and the leveraging down of the "leverage nut" on the end of this screw.
BDinTX
Dallas, Tx
Gotcha. To that last point - I had a battery fail and the dealer replaced under warranty. It was about a week after I washed and re-wound my winch line. I had put the vehicle in neutral but forgot about autopark until the winch had already dragged the jeep up the driveway with the rear tires locked. The dealership read codes and showed me there were quite a few overcurrent errors. They could have easily denied the battery claim, and probably rightfully should have.
JasonInDLH
JasonInDLH
Jason
MN
Hey Jason:
I never thought about putting the levers on top. I’ll probably order these up. Thanks for sharing!
JasonInDLH
JasonInDLH
Jason
MN
Is it possible to transfer a cable or two to the highlighted posts?
I tried the main connecter bolt, but it puts a lot of stress on my connectors. I thought the long stud wasn’t threaded correctly to accept a nut. I’ll check again. Thanks!
JasonInDLH
JasonInDLH
Jason
MN
I never noticed that sensor until tonight when I checked to see if I had it. It certainly was there!
I like your bracket idea. What thickness is the bracket? Do you think a thinner bracket would do it or would it be too flimsy?
JasonInDLH
JasonInDLH
Jason
MN
What if you drilled a little indentation for the factory nut to sit inside of?
BDinTX
Dallas, Tx
You know… that probably would have worked. I cut the end of the L off trying this (the last hole is threaded):
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block 98F0B83E-9DBC-4413-9168-D8A3147E0352
And then went to this, not perfect but better:
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block CAAE8CAD-363E-477E-BAF7-A0FE8F296AFD
Jeep Wrangler JL Looking for a Good Battery Post Distribution Block F7961CE2-4090-47BC-924E-339777BA2271
